worn out BX deck wheels
/ worn out BX deck wheels #1
dgraves49
Member
tecumseh michigan
kubota bx2350
You can call me cheap if you want. Faced with replacing all 4 deck wheels because the bore was worn out. I started looking for alternatives to spending 80 to 100 dollars for 4 cheap plastic wheels. I happened to have a short piece of 3/4" PEX tubing and when I checked it fit the shoulder on the bolt almost perfectly so I bored the holes in the wheels to 3/4" and had to tap the pex in with a hammer. When the pex wears out I can simply replace it until the outside of the wheels wear out.
/ worn out BX deck wheels #2
Good idea and agree the price of these el-cheapo plastic wheels are way over-priced.
/ worn out BX deck wheels #4
There is nothing wrong with what you did. He$$ if it works it is a good idea. Cost a lot less than new wheels. Good thinking!
/ worn out BX deck wheels #5
There was a guy on this forum a few years back that sold these wheels with a steel insert.
/ worn out BX deck wheels #6
When I had by BX22, I wore out a set of wheels pretty fast. I did not realise they should almost never contact the ground when mowing. They should only touch on occasion if mowing uneven ground to avoid scalping. After I made the adjustment, the next set was on for 5 years before I sold it and I think are still on today. ( sold 5 years ago ) .
/ worn out BX deck wheels #9
Try agsupply I think I only paid about $3.00ea.
My method cost me 1/2 hour of my time and some scrap PEX tubing. I just bought the machine last fall and they were already worn out when I got it. I keep the wheels set 1/2 inch off the ground as my manual suggests so I figure I should be good for several years.
Coats 5060AX Rim Clamp (A63118)
Coats 5060AX Rim...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
Adams Tilt Trailer (A63118)
Adams Tilt Trailer...
Mahindra 105S mForce Tractor (A64047)
Mahindra 105S...
