So I finally got a welder adding to my DIY possibilities
   / So I finally got a welder adding to my DIY possibilities #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
:laughing:
A decade and a half ago, my first career choice I was a steel fabricator at a local welding company. Learned a lot and was pretty decent at the job. Fast forward until now and I've only burned a few rods here and there. I need to fix my drum aerator because I forgot to drain the water out of it before winter. Well, the seam busted. Good excuse to get me a little MIG for around the house repairs.
Was set on the Hobart 115v at my local weld shop but ended up with a Norstar 115v. A littler cheaper but it has infinite heat selection unlike the Hobart with a 1-4 heat selection. Basically no fine tuning the heat. I got an Argon tank for it because, well Flux core stinks and I see welds rusting out a year later because the welds are dirty with flux. Anyhow, Sales guy said he is getting good reviews from guys in the field and sells a lot of them. My welding needs pop up maybe once a year if that. So this Chinese model "assembled and tested in USA" should do me just fine. BTW, apparently Hobart isn't all made in the USA either like they say??
   / So I finally got a welder adding to my DIY possibilities #2
Very few are ALL made in the US. Us it and have fun, I am dreaming of adding to my welder fleet. Got to get rid of some of the doubles first and then a small TIG for me. Ed
   / So I finally got a welder adding to my DIY possibilities #3
It's not assembled in USA unless they are putting the covers on here. It is from same factory as Eastwood, longevity and others.
Good to know, thanks.
   / So I finally got a welder adding to my DIY possibilities #5
What you planning on welding with Argon?
   / So I finally got a welder adding to my DIY possibilities #6
my hobart 140 says made in USA on the door.
Not with Argon unless your Tig welding, you need CO2 or CO2-Argon blend.
You can use strictly Argon, however depending on what you're welding it may not perform to one's liking ie; to cold of a bead, little penetration. It wouldn't be good for thick steel applications. Maybe better for sheet metal work.
I assume the bottle I have is an Argon blend. I always just say "Argon" when referring to the gas used with a MIG.
   / So I finally got a welder adding to my DIY possibilities #10
Sounds good
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
