So I finally got a welder adding to my DIY possibilities
   / So I finally got a welder adding to my DIY possibilities #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
:laughing:
A decade and a half ago, my first career choice I was a steel fabricator at a local welding company. Learned a lot and was pretty decent at the job. Fast forward until now and I've only burned a few rods here and there. I need to fix my drum aerator because I forgot to drain the water out of it before winter. Well, the seam busted. Good excuse to get me a little MIG for around the house repairs.
Was set on the Hobart 115v at my local weld shop but ended up with a Norstar 115v. A littler cheaper but it has infinite heat selection unlike the Hobart with a 1-4 heat selection. Basically no fine tuning the heat. I got an Argon tank for it because, well Flux core stinks and I see welds rusting out a year later because the welds are dirty with flux. Anyhow, Sales guy said he is getting good reviews from guys in the field and sells a lot of them. My welding needs pop up maybe once a year if that. So this Chinese model "assembled and tested in USA" should do me just fine. BTW, apparently Hobart isn't all made in the USA either like they say??
   / So I finally got a welder adding to my DIY possibilities #2
Very few are ALL made in the US. Us it and have fun, I am dreaming of adding to my welder fleet. Got to get rid of some of the doubles first and then a small TIG for me. Ed
   / So I finally got a welder adding to my DIY possibilities #3
It's not assembled in USA unless they are putting the covers on here. It is from same factory as Eastwood, longevity and others.
Good to know, thanks.
   / So I finally got a welder adding to my DIY possibilities #5
What you planning on welding with Argon?
   / So I finally got a welder adding to my DIY possibilities #6
my hobart 140 says made in USA on the door.
Not with Argon unless your Tig welding, you need CO2 or CO2-Argon blend.
You can use strictly Argon, however depending on what you're welding it may not perform to one's liking ie; to cold of a bead, little penetration. It wouldn't be good for thick steel applications. Maybe better for sheet metal work.
I assume the bottle I have is an Argon blend. I always just say "Argon" when referring to the gas used with a MIG.
   / So I finally got a welder adding to my DIY possibilities #10
Sounds good
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52128)
2017 Yale GLC050VX...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
