Adding an LED voltmeter to my Kioti DK35se
/ Adding an LED voltmeter to my Kioti DK35se
Yes, the green stands out and is really visible. I don't why the camera would not pick it up. I tried with and without the lights on in the pole barn.
Maybe the segments in the display are strobed by the display driver. Of course our eyes would integrate that and look continuous in the way a movie looks like continuous action when it is really just 24 frames a second stop motion.
/ Adding an LED voltmeter to my Kioti DK35se #22
------ I have attached pics although I am not sure why the camera did not pick up the voltage when on.-----------------------------
The camera did pick it up, it also got the other segments, maybe due to reflected light.
I see 12.5, the ones that are lit show up slightly wider.
On my picture, which shows up a little better, I "doctored" the picture, trying different filters and contrast controls until I got tired of playing with the picture and just posted it.
/ Adding an LED voltmeter to my Kioti DK35se #24
View attachment 438839View attachment 438836View attachment 438840View attachment 438837View attachment 438841View attachment 438838
I added one to my Branson 2400h. It is round, though works great. Tied it into the cruise control fuse so it is only on when the tractor is on. I have attached pics although I am not sure why the camera did not pick up the voltage when on. Also added a 12v outlet, which is tied to a fuse block attached to the battery.
Where did you get the gage? Nice job too!
/ Adding an LED voltmeter to my Kioti DK35se #25
Thanks for the compliment. I took my time and made sure I had clearance behind the panel. I was nervous as if I screwed up I would have a nice hole to figure out how to fix.
I used a hole saw and drilled a hole in a piece of wood first to ensure that I had the correct size, after all wood is cheap.
I got it at Amazon.com
Coromose 12V-24V Car Motorcycle LED DC Digital Display Voltmeter Waterproof Meter (Green) $4.95 plus $1.00 shipping. Of course it is a long ship time but for the price.
They have it in blue as well. I thought the green would stand out more.
Eric
/ Adding an LED voltmeter to my Kioti DK35se #27
I like the round style- would be easier to install than the rectangular ones I have put in. Installing them is an easy and cheap mod that is potentially very useful.
/ Adding an LED voltmeter to my Kioti DK35se #28
Oh, and after looking at the blue one, I decided to buy it as a backup. At the price why not?
/ Adding an LED voltmeter to my Kioti DK35se #29
Here is the one I added a while back.
/ Adding an LED voltmeter to my Kioti DK35se #31
After reading this thread I decided to pick on of these meters up myself. Would it be a big drain on the battery if it is connected to always be on? These meters can be picked up on ebay or aliexpress for $3 or less shipped.
I am not sure how much current it draws, but I would think it would drain the battery down in less than a week. It sure needs to be put on a key switched power source in my opinion.
/ Adding an LED voltmeter to my Kioti DK35se #33
Agreed; any current draw will drain your battery down to nothing, eventually. Not good for the battery to go below 80% of full charge regularly, it will kill the life of your battery by a significant amount.
/ Adding an LED voltmeter to my Kioti DK35se #34
I agree with the others, connect it to a switched supply to prevent parasitic battery drain. Always try to avoid constant battery drains. However small they may be, they do add up over time and will lead to shorter battery life. If you must connect it directly to the battery, add a push button switch in series as you probably don't need a constant voltage reading.
/ Adding an LED voltmeter to my Kioti DK35se #35
Thanks for the advice. I am using a marine rocker switch for my LED lights. I believe I should be able to connect to the switch and have it power on the voltage display when the switch is in the on position.
Please don't accidently leave the rocker switch in the on position as you take your key and get off of the tractor.:) I suppose if your LED lights are also on you would notice it.
/ Adding an LED voltmeter to my Kioti DK35se #37
Here's my copy of your voltmeter on my kubota bx1860.1463206271653.jpg hard to see from the seat, but easy standing next to the tractor.
Tied into a wire in the blinker switch by removing the pin from the connector and soldering a wire on, then putting it back in. So I could remove it without leaving skint wires.
/ Adding an LED voltmeter to my Kioti DK35se #39
/ Adding an LED voltmeter to my Kioti DK35se #40
Here's my install of an oil pressure gauge and volt meter on my little Yanmar. Voltmeter is connected to key power so it goes off when key is turned off.
2010 Ford Mustang Sedan (A61569)
2010 Ford Mustang...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A61307)
2023 Top Air ATV...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Rooster Weathervane (A55853)
Rooster...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
