Why do most tractors with FEL's.........................
   / Why do most tractors with FEL's......................... #51
Large commercial equipment seems to usually have the cylinder base closest to the valves. Less exposed lines and hoses that way. Lines and hoses farther away from something to snag them.
But you can always find exceptions:
Bruce
   / Why do most tractors with FEL's......................... #52
Read up on calculating hydraulic force which takes into account piston on area. One side of the piston has less area for the oil to push against thus will have less applied from that side.
Bruce, think about it this way: cylinder extension is stronger than cylinder retraction. cylinder extension is hydro pressure on the "big face" of the piston pushing the rod out the other end, doesn't matter which way the cylinder is oriented. Retraction is weaker, because it's the "small face" of the piston.
In other words, a vertically mounted cylinder lifting a weight will generate the same lifting force, whether it's rod end up or cylinder end up. Well, except for the relative weights of the cylinder and the rod...
   / Why do most tractors with FEL's......................... #53
Bruce got it. DIRT. If the rod is on top, dirt builds up on the gland seal and it starts leaking sooner.
They've been turning cylinders upside-down on dump trailers for years. TruckPaper.com | 217 BRAZOS Half Round For Sale
http://media.sandhills.com/img.axd?...4WwNIrw6wXNaHlv8qun++PowRD11Fksw1L0iTB+5J+A3y
That is correct. The old loaders had the lift cylinders with the rod end facing up. When you lower the loader with a load on it a vacuum is created at the rod seal and will pull in water through the seal. With the rod facing up the water runs down to the seal. I live in Minnesota and the hydraulic oil would get full of water and freeze when pushing snow. The cylinders where installed with the rod down and the water runs away from the seal. Have not had any problems since the manufacturer turned the cylinders around. Also cylinder seals are better now than 40 years ago.
   / Why do most tractors with FEL's......................... #54
Bruce
That's why I said usually, that is a beast of a machine.
   / Why do most tractors with FEL's......................... #55
Whether the cylinder is mounted up or down, when you raise the loader bucket, the cylinder is extending, not retracting. Where's a good animated GIF of a cylinder? Some folks (me sometimes, too) need pictures.
   / Why do most tractors with FEL's......................... #56
Either way, mounted up or down, its the same force extending.
466909d1462066764-why-do-most-tractors-fels-animation3-gif
466910d1462066779-why-do-most-tractors-fels-animation4-gif
   / Why do most tractors with FEL's......................... #57
Wow, those are some poor animations! :laughing:
   / Why do most tractors with FEL's......................... #58
I find it mind boggling that someone can think Simply turning a cylinder upside down somehow changes its extend force or speed. I understand people slip up, have a brain fart, etc. But when explained so clearly many times, and to still argue the point....:mur:
As to the original question....
I have always believed/been told that it is about hose routing. Really not anything about making it cheaper or easier. But less hose flex/movement. Keep the base of the cylinder (which remains stationary...only rotates).....and thats the end you want connected to the part the hoses are attached to.
My kubota loader has lines running down the loader. thus base end up like the pic of the mahindra. If they were reversed, and the base end were attached to the frame.....in order to have the hoses still coming from the loader, they would need to be made long enough to reach when a full loader height....then would "appear" to be way too long when lowered.
Think about a simple logsplitter. Reverse the cylinder on that (yes it will still have the same force).
But instead of the valves and hoses staying stationary, everytime you split....valve (if hooked direct to cylinder like huskee), and hoses all move back and forth with every cycle. Thus need to be made longer for full extend....and would have a mile extra when retracted.
   / Why do most tractors with FEL's......................... #59
I think that's because the rod takes up some space but on the other side there's no rod-just a flat piston head thus giving you an inch or two more area.
It's easy to calculate. The ratio of force between extension and retraction is x:y, where x is the area of the piston face (or cylinder), and y is the area of the piston face minus the cross-section area of the rod. Or, by factoring, it's the cylinder diameter squared versus the cylinder diameter squared - the rod area squared. A 2" diameter piston and 1" rod gives a 4:3 ratio. At 1000 PSI, you get a 2*3.14*1000 extension force (about 6200 pounds), multiply that by 3:4 to get the retraction force (about 4600 pounds).
[I know just enough about hydraulics and pneumatics to get myself in trouble ;-)]
   / Why do most tractors with FEL's......................... #60
This is almost as bad as that front axle weight debate thread. How would anyone think that simply flipping a cylinder end for end would reduce its forces? Technically it would, but only by the weight of the barrel, but that's like 20 pounds on something that pushes several tons. On a side note, most wheel loaders have a lever that allows the bucket to be curled up while extending the cylinder.
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
