pto engine engage speed
/ pto engine engage speed #1
allthumbs23
WI
Kubota BX2230
On a BX2230 where should my engine rpms be when engaging the mower PTO? Hi or low? Thanks
/ pto engine engage speed #3
^^^agree^^^
/ pto engine engage speed #4
If you want to go by the manual, it recommends half throttle for engagement.
/ pto engine engage speed #5
I always kick my PTO in AND OUT at a dead idle; however when my brother bought his little john Deere (a 7xx something or other) the salesman told him that john Deere says to engage and disengage at full pto rpm. This just seems bull to me. It's like revving your truck up and dumping the clutch every time.
/ pto engine engage speed #6
I'm not a fan of engaging pto at idle, it's hard on the engine to lug it down.
My B uses a dry manual clutch rather then the hyd. wet clutch in the BX but I usually engage pto about 1/2 throttle to maybe just above, depends on the implement.
/ pto engine engage speed #7
I had my dads DX25e case for three years before I bought my john Deere and it was better that nothing by far but certainly not what I wanted. The one thing I really miss though was the PTO was engaged with a lever and you could gently ease into it unlike the john Deere with the solid on off button. I don't know anything much about the inner workings of that case but I swear the PTO was run off of a hydraulic motor because I was blowing snow right close to the neighbours house and being I had never been there before I was doing the first pass at just above idle and picked up a piece of firewood and it just stopped and lugged down a bit when I kicked it out. It never sheared the pin or stalled the tractor.
/ pto engine engage speed #8
Will bring the BX2230 above idle where the hydraulic flow starts to make the loader quicker and engage the PTO, no lugging the engine and quick engagement of the hydraulic clutch pack.
David
/ pto engine engage speed #9
A lot of folks reiterate engaging the driveline only at idle d/t worrying about shocking the system with a harsh engagement... a LOT of manufacturers don't seem to want heavy loads transferred to the tractor engine at startup. I'm not sure if the difference is in the clutch type, driveline size, or what... but if YOUR manufacturer recommend engaging YOUR unit at a particular RPM, then that is the recommended method for your particular situation. There are subtle and not-so-subtle design differences between and within manufacturing lines. There is a certain logic to not shocking the driveline, as there is to not lugging the engine at low rpm's... where to draw the line isn't a mystery when your manufacturer spells out their recommendation in the manual. Choosing not to follow written directions from the manufacturer is up to you, but they don't print manuals and make recommendations just to keep consumers on their toes and look busy, and tractors aren't getting any cheaper... I'd rather damage an implement or clutch than an engine.
/ pto engine engage speed #10
I cut my shear pins into 3 pieces when engaging at PTO speed with my M4700 and my rotary cutter. Slices them quicker and easier than using a hacksaw.
/ pto engine engage speed #11
I bring the engine above idle - 1000 to 1200 - and slowly engage the pto. No engine lugging with this procedure.
/ pto engine engage speed #12
The manual for my BX2350 witch should be similar recommends 1/2 throttle and engaging the PTO clutch slowly. Mine starts to engage after moving about 3/4 of the way. once the blades start moving fully engage it.
/ pto engine engage speed #13
If you can slowly engage the PTO, it makes no difference what engine speed is. By slowly moving the lever to slowly engage the clutch, it starts everything smoothly. Excessive engine speed would only cause a bit more slipping of the clutch (or belts in some cases). HOWEVER for those of us with the one button to push or pull to engage the PTO, slower engine speed is a must. My BIL has a shear pin on his bush hog and if you are above idle more than 200 RPM then you will be replacing the shear pin. Even after going to a grade 5 bolt, it will shear the pin if you are above 1000 rpm.
I really hate the electronic PTO switches on tractors without a clutch that you cant slowing engage the PTO. I sure seems like they put a lot of stress on everything from the motor to the piece of equipment. MY LS has the button, but by fully engaging the clutch, I can still slowly start the PTO turning by slipping the clutch a bit.
Idle with no load on the mower, IOW, on the pavement.
Thanks everyone. What is IOW?
I a used to have a JD GT235 and you had to engage the deck at max throttle or it would kill the engine every time. It did have the larger deck, but still....
/ pto engine engage speed #15
IOW...In other words....
Never start any pto drive with the motor cranked up. Puts way too much shock load on the shafting and U joints.
/ pto engine engage speed #16
It depends on how freewheeling the deck is. If you have a bunch of v-belts in the deck drive, it will take more rpm to get it moving.
/ pto engine engage speed #17
Well, it does. It depends on how much clutch slipping you want to do. Do you want to slip it to only 100 pto rpm or do you want to slip it to 600? Every tractor is different and may need some throttle input to engage the pto. The higher the rpm, the more heat generated in the clutch. Just find the best rpm for your equipment.
/ pto engine engage speed #18
I don't think the salesman knew what he was talking about!
I have a Deere Z920 zero turn with the Kawasaki gas engine. The manual states (IIRC) half throttle...and that's what I use. Any tractor PTO driven implement is engaged at low idle RPM. The only implement that I've had that needed a bit more RPM was a rotary cutter...and I used the foot throttle if necessary.
/ pto engine engage speed #19
The Deere x7** garden tractors have the electronic pto switch. When you are mowing and start to back up, the pto shuts off. Then when you start forward again, you have to engage it again. This is all done at full throttle and they seem to last a long time. I'm not a fan of the pto clutch going through that much on/off switching either.
2021 Ford Explorer AWD SUV (A61574)
2021 Ford Explorer...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2014 International 4300 Single Axle Dump Truck (A62613)
2014 International...
