Tilt Cylinder Pin Dimension Chart?
/ Tilt Cylinder Pin Dimension Chart? #1
Steelart99
Peyton, CO
Ford CL40 Skid Steer
I need to replace the tilt cylinder pins on an old Ford CL40 Skid Steer. Parts are no longer available! So, I'm trying to find a chart of tilt cylinder pins so that I can locate a replacement based on size. Does anyone know of a chart? The pins are 1-1/4" diameter by 3-1/2" long and have the flange on them.
/ Tilt Cylinder Pin Dimension Chart? #2
Try McMaster-Carr, they have all kinds if hdwe. I looked but a pain in the phone. Great web site.
Jim
Make one from cold rolled steel shafting. A picture of the removed pin would help with other ideas for you.
Ron
I expect I could make one (or two ... or three) if needed. Just easier at this point to buy them if they are not too expensive. My problem is that the previous owner (who passed away) seemed to have a torch and a welder as his only tools ... and he wasn't very good with either. He'd replaced one of the pins with a bolt that was twice as long as it was supposed to be and there was interference and thus damage with some of the other lift parts. I want to pull the bolt and replace it appropriately and also clean up all the nasty welding done on the machine. I may have to pull a pin from the other side just to have the exact dimensions (and a picture).
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2008 Bush Hog 3715 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
2008 Bush Hog 3715...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
Caterpillar 214-224 Wheel Type Excavator Service and Parts Manuals (A63117)
Caterpillar...
2016 Kia Sorento SUV (A61574)
2016 Kia Sorento...
2025 28in Forks and Frame Mini Skid Steer Attachment (A61572)
2025 28in Forks...
