MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,536
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Hi Moss, I was saying to make the hole big enough for the bushing with a plasma cutter and then weld the bushing in place filling in where necessary. I would trust that more than welding the new tab on. My welds have never failed but I am always worrying about them.
Ken
Gotcha! If you have access to a plasma cutter that would work, I guess. But if you're going to go through the trouble of plasma cutting a hole, grinding, fitting a bushing, welding the bushing, etc..., why not just cut off the tabs and weld new ones on? Trying to stay away from the tank?
How would you plasma cut the lower tab? Or is the lower tab not damaged?
For bushings, was it you I was having discussions with about the bushings in the blades and using DOM tubing VS iron pipe? Anyhow, On Line Metals has small quantities of DOM tubing. Online Metal Store | Small Quantity Metal Orders | Metal Cutting, Sales & Shipping | Buy Steel, Aluminum, Copper, Brass, Stainless | Metal Product Guides at OnlineMetals.com
