UTV or SCUT - New Land Owner and First Time Buyer
   / UTV or SCUT - New Land Owner and First Time Buyer #11
Owning a JD Gator diesel 4x4 I can say this unit has done lots of work for me, but it's no tractor. There are more useful UTV's than mine perhaps but I like the smooth ride and the fact I can disconnect the front drive and one rear wheel just by flipping a switch and lever, same as a car does and not tear up the grass. The dump box is a real work and time saver for us and not something I'd be without if getting another. Like others have said, get the tractor first and for all the heavy work then the UTV for lighter work.
RICN
   / UTV or SCUT - New Land Owner and First Time Buyer #12
Definitely tractor. You can buy a golf cart to scoot around with but the UTV will never do the work a tractor and loader will and you will get into it. Also, you need more than a SCUT - 35hp or so with FWA and Loader and back blade at a minimum.
   / UTV or SCUT - New Land Owner and First Time Buyer #13
I have both-but I had my tractor first!
Will
   / UTV or SCUT - New Land Owner and First Time Buyer #14
Pretty consistent opinions here, for good reason. Your chore list tilts heavily to work where the machine needs some heft and pulling/pushing/lifting power. That's a tractor, not a UTV... even a beefed-up version. The UTV can work well for snow plowing, but otherwise it's a cinch a tractor will be much more effective in getting your work done.
I'd also agree that your amount of property will most likely bring you challenges better met with a bigger tool than the 25 hp setup you're looking at.
   / UTV or SCUT - New Land Owner and First Time Buyer #15
Tractor- a good quality tractor will work harder, and last a lot longer doing heavy work than a UTV. While my UTV does do a lot of work it is not close to the amount the tractor can and does do.
Hi All -
Thank you everyone for the insight, options and opinions. I have taken the Brutus out of the mix and now I'm down to the following tractor options.
1) 2016 LS XG3032H
2) 2016 McCormick X1.35 ($300 more than the LS)
The MCormick is more heavy duty but is not offered with hydrostat and the engine does not have turbo.
I'm looking forward to making a decision soon and getting started.
Thank you
   / UTV or SCUT - New Land Owner and First Time Buyer #17
I agree with Grandad. You could tear up a nice UTV trying to do the work it wasn't designed for. Tractor all the way for that work and I also agree you probably want to go bigger than a SCUT... But if you $$$ is limited a SCUT is better than nothing. You will find that 35 acres pretty useless until you have a tractor.
   / UTV or SCUT - New Land Owner and First Time Buyer #18
$300 is nothing over the life of a tractor 1000 lbs is - go with the McCormick - you will appreciate the extra tractor.
Thank you everyone for your time, input & opinions. I decided to go with the LS 3032H tractor. Tractor should be arriving this week so I can get to work on my property & food plots.
   / UTV or SCUT - New Land Owner and First Time Buyer #20
PICTURES, when you get it. Congratulations on the new LS.
2016 MACK GU713 GRANITE DUMP TRUCK (A51222)
2016 MACK GU713...
2014 New Holland T8.360 MFWD Tractor (A52128)
2014 New Holland...
2015 Nissan Pathfinder Platinum SUV (A50324)
2015 Nissan...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2008 Suzuki XL7 SUV (A50324)
2008 Suzuki XL7...
Wooden Round Table (A49462)
Wooden Round Table...
