Member Map
   / Member Map #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
Came across this idea on another tractor forum.
Anything like that been discussion or considered here?
   / Member Map #2
Hope not!:thumbdown:
   / Member Map
I'd see it based upon your location. If it's not precise enough...city/state....you wouldn't show. In your case somewhere in Washington would leave you out.
   / Member Map #6
What would be the purpose of the member map? What are you thinking?
   / Member Map #7
Thought we did it here a long time ago. It was fun for a little bit seeing where other lived, but not really all that interesting.
   / Member Map
That's the only reason I have...just to see how the members are spread through the nation...world.
   / Member Map #9
Seven or eight years ago there was a site called Frappr that made a splash on forums, where you could put a pin in your location, worldwide. It went away and I don't know if anything took its place, haven't looked lately.
   / Member Map #10
What if you are the only REAL member, and all the rest of the posts are just generated by the mental hospital's computer to keep you occupied and somewhat content ??? Heh, it could happen..!!! :)
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A50860)
2025 KG43 UNUSED...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
12 FLATBED W/ PRESSURE WASHER FRAME (A50854)
12 FLATBED W/...
1994 Toyota 6000lbs 2 Stage Forklift (A51039)
1994 Toyota...
