weed and grass killer.
/ weed and grass killer. #1
coffeeman
would last years Roundup type killer be ok this year or would it lose it's power? I have old stuff that was left in cold all winter. It was cold enough to freeze. It is concentrated. directions were for 2 1/2 ounces per gallon.
Thanks all.
Coffeeman
/ weed and grass killer. #2
should be ok, Try some and see if it works. Mix 3 oz to the gallon.
/ weed and grass killer. #3
I have used five year old weed killer that still worked fine.
/ weed and grass killer. #4
What's to loose if it doesn't work?
/ weed and grass killer. #5
You can try it, but I had some Roundup once that had frozen and it was useless after that, but it was the premixed stuff, so you may have better luck. As 4570man said, what have you got to loose?
/ weed and grass killer. #6
Yep, we've used old Roundup concentrate and it works great, we buy several gallons at a time as it's cheaper.
/ weed and grass killer. #8
Think no problem. I've kept and used from one season to the next. Only trouble I've had is with stuff mixed up. It gets like strings in it. Only mix up what I plan to use. Actually, mostly use it to paint concentrated on stems and leaves now.
Ralph
/ weed and grass killer. #9
I have some that is 3 years old and it still works. It has been stored in my unheated shop over winter but I don't think it ever froze.
/ weed and grass killer. #10
Just used some last week from my 5 year old jug. Stored in unheated area of shop whole time. Worked fine weeds dying out on 3rd day after application.
/ weed and grass killer. #11
Agree with the other posters here, I buy in bulk, and use the carry over every year with no drop off in results. The one thing I would look for is a change in color or gelling if it froze during the winter, but I haven't ever seen that happen.
Well it didn't work. I used 2 1/2 ounces of concentrate per gallon. Glyphosate 41 %. However, closer look at directions says it takes 1 - 2 weeks to work. I thought it would work sooner.. So i still have a couple days to see if works.
/ weed and grass killer. #13
There are several types of Roundup with different kill times, Roundup Ultra, Roundup Ultra Max, Roundup extended control etc. Roundup Ready beans and such are used so much here it has gotten to the points some of the other plants are getting resistent and we have to spray more often than in the past.
/ weed and grass killer. #14
Coffeman, give it a few days to work, depending on what you put it on. I put some glyphosate on some prickly pear cactus once to see what it would do. In a couple of weeks the cactus had black splotches on it and it was wilting badly. The cactus eventually fell down, but then it came back with new green pads growing out from the roots. Last year I used some Surmount on cactus and that seems to work well.
2011 FORD F-150 (A65643)
2011 FORD F-150...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2015 Nissan Frontier 4x4 Crew Cab Pickup Truck (A61573)
2015 Nissan...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65579)
New/Unused AGT...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
