Just bought a bush hog, what to look for??
   / Just bought a bush hog, what to look for?? #1
Bansil
Gold Member
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
Wife just texted me and she bought a bush hog off someone at her work
All I know is it is a 6 ft and worked when parked last year, so what to look for?
good splines on pto?
gearbox lubricated?
no hardened bolts in shear holes?
good bearings?
no major cracks?
Anything else?
Thanks
   / Just bought a bush hog, what to look for?? #2
gearbox lubricated?
good bearings?
no major cracks?
Anything else?
Thanks
Oh, boy! This should be fun to see what you get!:D Sounds like you have the bases covered on what to check. But God only knows what you are getting in the way of a cutter. Might be the bargain of the century, or might be a "pile". Guess time will tell, keep us posted..
   / Just bought a bush hog, what to look for?? #3
What did she pay?
   / Just bought a bush hog, what to look for?? #4
How bent up is 3 point hitch mounts (i.e. how level when mowing)
Any sheet metal bent (i.e. can blades turn fully without striking edge.) Actually, it's optional checking this, you'll know VERY quickly when you spin it up. (BANG! BANG! BANG!) :rolleyes:
Major gouges on blades that require grounding and/or cracks that require replacement?
Can blades rotate/fold back freely at their connection on the stump jumper?
Are blades bent? (i.e. are blades at the same relative height?)
   / Just bought a bush hog, what to look for?? #5
I'm with James. This will be interesting..... :)
   / Just bought a bush hog, what to look for?? #7
Post pics and observations when you get it, then we can go from there.
it was $200, upon seeing it this weekend, it is one of her techs fathers bush hog
they bought a tractor and it came with this, and they do not use it because they also have a belly mower?
I will add pictures once I take some
So far I have gotten some good sdeals on stuff, mainly if you have cash a blank bill of sale and trailer...you can get stuff cheaper :D
:confused2:
must google....
Thanks for video!
   / Just bought a bush hog, what to look for?? #11
:confused2:
must google....
What he was referring to is the blades are typically mounted onto a "stump jumper" pan with shoulder bolts that allow the blades to pivot some. This is so when a blade hits a solid object, the blade will swing back some and lessen the impact to the gearbox.
Thanks,
I see that some do and some dont...hope to see this on friday
   / Just bought a bush hog, what to look for?? #13
"no hardened bolts in shear holes?"
Find out what the proper shear bolt is and use it. You need to get a user manual, good for lots of things. Don't assume that the shear bolt should be soft. Also, don't trust the shear bolt now installed to be the correct one. Some people use bolts too hard, some use bolts too soft. Too soft and you may be replacing it often, too hard and you will be breaking expensive things.
Pat
You may have a slip clutch rather than a shear bolt.
   / Just bought a bush hog, what to look for?? #14
$200 is just about scrap price for a 6' cutter. If it works for just 1 use, you got a good deal on it.
If it doesn't have one already, I'd suggest putting in a slip clutch instead of shear bolts. My slip clutch has saved my tractor a lot of abuse but then, I'm pretty hard on my cutter. I figure if I can roll the tractor over it, then the cutter should cut it.
   / Just bought a bush hog, what to look for?? #15
Find out what the proper shear bolt is and use it. You need to get a user manual, good for lots of things. ...... Too soft and you may be replacing it often, too hard and you will be breaking expensive things.
Pat
...and if you do have a slip clutch. Note where the bolts are adjusted (measure or count the threads), loosen it up, give it a quick start to knock the rust off it and make sure it slips, and then retighten.
okay thanks!
I won't be using it for a couple weeks, too much other stuff to do, like build my ROPS and install seatbelt ;)
Once I figure out who/what it is I will snap pictures and look for a manual online
So far have been lucky with manuals...I hate the internet at times, but finding manuals for all this old stuff I have been getting would of been a nightmare
   / Just bought a bush hog, what to look for?? #17
:confused2:
must google....
A picture of a stump jumper with one blade folded back:
Xfaxman :drink: that is easiest explanation!
Just like when you were hanging onto the merry go round and your legs hit a friend that was spinning you, you fold right into the merry go round :confused2:
:laughing:
   / Just bought a bush hog, what to look for?? #20
Folding blades are also available on cutters without a stump jumper pan. There is simply a flat bar with a splined center hole to fasten to the gearbox shaft. The blades then fasten to that flatbar with bushings that allow swing.
The purpose of a stump jumper is not to allow the blades to swing freely. It's purpose is to "ride up" over a hidden stump or rock or any other obstacle. Without it the flatbar and gearbox shaft are vulnerable to severe shock from banging against said obstacle. :(
If you have a choice, always choose stump jumper.
Adams 5T Fertilizer Spreader (A56438)
Adams 5T...
500BBL WHEELED...
2018 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2018 FORD F-150 XL...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
