Diesel Can Spout Mechanism Into the Tank
   / Diesel Can Spout Mechanism Into the Tank #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
I was just putting some diesel into my RX7320 PC and the EPA spout mechanism came off and went in the tank.
Is there anything mechanical or otherwise that will be damaged if I run the tractor?
Any ideas on how to get the spout mechanism out?
   / Diesel Can Spout Mechanism Into the Tank #2
Is it plastic or metal? If metal maybe you can fish it out with a magnet. If it were mine, I'd get it out.
Then I'd go get a useable spout for the can. EZ-Pour Hi-Flo Replacement Spout - For Life Out Here
Is there anything mechanical in the tank which would be damaged by engaging with the spout and/or spring?
I need to know because I have an immediate need (maple sap collecting) to use the tractor and get the spout / spring out later.
   / Diesel Can Spout Mechanism Into the Tank #6
My guess would be that if there in an in tank pump it has a strainer on it so that would keep anything bad from happening. If there is just an opening in the bottom for the fuel line, they spout is likely too large to block it.
Other than that, I'd say go for it and see what happens. The worst would be the rubber O ring floating around in there causing mischief.
   / Diesel Can Spout Mechanism Into the Tank #7
One of those little four-claw grabber things from the dollar store?
   / Diesel Can Spout Mechanism Into the Tank #8
Lots of options. :)
Probably the one on an excavator won't fit your tank spout.
grabbers
Bruce
   / Diesel Can Spout Mechanism Into the Tank #9
Every year a tractor owner gets to go fishing. Sometimes 2 owners.
Metal Bigfoot with Flag Lawn Art (A55853)
Metal Bigfoot with...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
UNUSED 1RANCH 1RIG-13' 14' BI-PARTING IRON GATE (A57193)
UNUSED 1RANCH...
Pallet of 7' LED Lights (A56469)
Pallet of 7' LED...
HUTCH MASTER 12' OFF SET DISC HARROW (A57192)
HUTCH MASTER 12'...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
