Threepoint box blade to pull type conversion.
/ Threepoint box blade to pull type conversion. #41
You done a great job on it.
/ Threepoint box blade to pull type conversion. #42
That is so cool!
Thank you, it's worked great so far, only thing I'm going to add is a rod on the tilt cylinder so I can set the blade back flat while using it. Thinking of doing a rod with a bent notch like on most loaders.
/ Threepoint box blade to pull type conversion. #46
I thought I replied to the videos but I guess I didn't. Looks like it is working good. It looked like the hydraulics works very fast. I hope it isn't to fast to make those fine adjustments. Great work on your project!
/ Threepoint box blade to pull type conversion. #47
We know all about proper hydraulic speed don't we George. Restrictor fittings can be added if needed.
/ Threepoint box blade to pull type conversion. #48
yeah it can be a bear if they work to fast or too slow either one. I've had a little of both.
/ Threepoint box blade to pull type conversion. #49
I had a 3 point backhoe that used a washer with a small hole in it, to slow down the swing speed. The outside diameter of the washer was slightly smaller than the ID of the coupler that screwed onto the hose for the swing cylinder.
So anyone can make their own flow restrictor . :thumbsup:
Thanks everyone, it turned out just as I hoped and has worked great.
(INOP) 2016 POLARIS RANGER 570 EFI RTV (A64280)
(INOP) 2016...
John Deere 1790 Planter (A66285)
John Deere 1790...
NEW HOLLAND TC35A TRACTOR (A64280)
NEW HOLLAND TC35A...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
Bomag Roller (A63689)
(2) UNUSED 380/85R30 TIRES W/ 10 LUG RIMS (A64280)
(2) UNUSED...
