Disc Harrow Disc for 100hp tractor
/ Disc for 100hp tractor #1
TNRifleman
Murfreesboro TN
John Deere 5100E
I am relatively new to all of this and need a lot of guidance.
I have a very hilly piece of property, about 550 acres. There are several small fields (2-4 acres) at different locations that I am wanting to foodplot primarily for deer. These fields have not been turned in a long time and I am trying to get them prepped for planting right now without buying the wrong equipment out of ignorance.
From what I am reading, hearing and watching on the internet a disc harrow is the most essential piece of equipment. All of my fields have been sprayed thoroughly with round-up and are good and dead. I am hoping a serious disc will break up the top adequately and I will not have to have a moldboard plow. I have also heard this is desirable to leave the ground un-plowed for stabilization against erosion especially on slopes.
I would like to hear thoughts on the possibility of not plowing.
My real question is about the disc because I know I have to have that piece of equipment. Most of the disc that I am looking at online that look like they would be adequate and maneuverable in smaller fields are rated by a max HP much lower than my JD 5100E. Disc rated for tractors in the 100hp range look really big, complicated and expensive. I have to access some of these fields with existing logging roads that my 10' cutter will barely squeak through.
Are there 3 point disc that are appropriate for 2 acre fields and will not break behind a larger tractor? Any experienced input is appreciated.
/ Disc for 100hp tractor #2
Welcome to TBN.
In my opinion, disc power ratings are related to what is needed for the disc's weight and width, not that a larger tractor will overpower it. I don't think there is much danger to a disc by pulling it with a larger tractor.
Sort of like asking if a F3500 truck can pull a little, lightweight boat trailer without hurting it.
Bruce
/ Disc for 100hp tractor #3
There are lots of choices in discs and it depends on what you want to do. For discing 4-5 inches deep your tractor should be able to handle a 14' tandem disc very nicely. If you want to go deeper then you will need to go smaller. Offset discs - where the front gang is all angled in one direction and the back gang in the opposite direction - are more like plowing in that they will work deeper and pull harder. These are more comparable to a moldboard plow versus a disc harrow which is used lighter and shallower.
For what you are asking about I would recommend a disc harrow and working about 4" deep.
Personally I see no reason to plow in today's world and would not own one. Even if you plow you will have to disc it (or something else like a cultimulcher) before you seed it.
Also, I do not believe a 3 opt mounted disc floats properly and threrefore recommend a pull behind.
OK, thanks. I was jst going to ask about the pull types. I see landpride has a pull behind that is 10 or 12' wide. I should be able to get that through all my roads. It is also rated for 45-100 hp.
/ Disc for 100hp tractor #6
I would buy a Disc Harrow with 22" diameter pans and a Category 2 Three Point Hitch in whatever width you desire. Generally for food plots, where most operators maneuver between trees, a Disc Harrow a little narrower than rear tires is desirable. With gang angles adjusted about mid-point in aggressiveness, such a Disc should cut about 4" deep. The bed behind the harrow should be reasonably smooth. If you adjust such a Disc very aggressively (no need) it should cut 8" deep but the bed behind the tractor will be rougher.
No surprise: Notched pans cut considerably more effectively than round, un-notched, pans. After glcophosphate the crop residue/fallow grass, will still be in place. Go notched.
A Three Point Hitch mounted Tandem Disc Harrow is highly maneuverable. Towed Disc Harrows cannot be lifted; they require considerable headland to swing around.
If your food plots are 2-4 acres why consider a 10' to 12' wide Disc Harrow?
FYI: The key metric is implement pressure bearing on each pan. Fifty pounds weight per pan is a good beginning, sixty pounds per pan is nirvana.
/ Disc for 100hp tractor #7
I agree with Jeff a pull type harrow is going to be a headache trying to turn in a 2-4 acre spot. A 3 point type you can use the brakes to turn in your tracks in the length of the tractor.
/ Disc for 100hp tractor #9
Based on the info that you have given, if I were you, I would be looking at the 9 footers here.
Assuming that you don't want to waste time, I personally would not even consider anything under 2000lbs. But that's just me. ;)
An offset is great but he's going to need to follow with another implement of some sort to finish the seed bed, a tandem could do both potentially.
/ Disc for 100hp tractor #10
Your talking about 2-4 acres total, or several times this? Growing up we managed about 50 acres of tillage. Small farm of my grandfather's. We would plant 10-15 acres of millet for hay and to be able to shoot dove over. Usually 5-10acres of corn, and when really working like a true farm, 30-50 acres of soybeans. Two 90 hp tractors, 8' pull behind disk. Usually would plow twice, row up and plant..... Ground had clay, no rocks. For your purpose, I'd find a 6to 8' plain disk, probably a simple harrow to flatten back down.. Go used, disk will last decades as long as it wasn't too abused.
/ Disc for 100hp tractor #11
I'm no farmer. So this should not be planted for a food plot? :confused:
/ Disc for 100hp tractor #12
I can't tell from that picture way to far off but mostly depends on what your planning to plant.
/ Disc for 100hp tractor #13
Doesn't make any difference, I wasn't planting anything, just getting rid of the weeds. I've rototilled ground before and it was no better than what is in the picture.
/ Disc for 100hp tractor #14
I would say that's not the norm but is possible under perfect soil conditions, there is a reason you don't see farmers pulling offsets but see tandems all the time at least around here.
/ Disc for 100hp tractor #15
If it is a food plot why not just no till it in? A lot easier.
/ Disc for 100hp tractor #17
Offsets are made to till up harder ground or that with more debris. They are more aggressive. A tandem disc won't cut in as hard as an offset. Farmers use tandems because the land is regularly worked, they provide a better finish, and not to mention you can pull a wider tandem disc then an offset.
I am talking about six or seven 2 acre plots distributed over 550 acres. maybe a few more smaller plots too.
OK, I have looked at that option but don't I need to turn in the lime and fertilizer? It seems that if i just throw it on these slopes it will just end up in the creek.....
/ Disc for 100hp tractor #20
Fertilizer can be placed in. I have never done lime but I would think that is very soluble.
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
UNUSED WOLVERINE TREE DIGGER (A64281)
UNUSED WOLVERINE...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
