Cell Signal Boosters
   / Cell Signal Boosters #111
Using R11 cables with the Wilson 75ohm unit that N80 has, you would need an adaptor at each end of each cable. Would adding those 4 connectors/adapters to the line create any loss?
   / Cell Signal Boosters #112
A slight amount yes, Maybe .25 to .5 Db per connector depending on construction quality. Specifications may be hard to obtain for some of these items.. but in general, everything cost's. There is some loss in everything.
   / Cell Signal Boosters #113
Thanks. That's minimal loss.
When using boosters like this, does it affect a call when you walk outside the internal antenna range, and you jump to the tower directly?
   / Cell Signal Boosters #114
Now that is a question I don't have an answer for. a very good question. Perhaps some of the owners of these boosters could help here.
   / Cell Signal Boosters #115
I never knew there is so much to this... learn something everyday at TBN.
Thanks KOua... (Not that I understand all of it)
   / Cell Signal Boosters #116
For example RG11 which is also a 75 ohm coax like RG6 will have to have different connectors to accommodate its increased physical size. and if you need to terminate it with an F type connector you will need an adaptor.
An engineer at Wilson Electronics recommended I switch to RG11 cable, which I did. I couldn't find the right connectors, and ended up using the gold plated screw on jobs from a big box store. Can you point me in the right direction with a source, or even just a name, for the correct weatherproof connectors? Hard to search for something when you don't even know the proper name for it. :confused2:
   / Cell Signal Boosters #117
I have dealt with these people before and they seem OK
Here is a crimp on F connector that fits the larger RG11 cable. and a compression type
Holland SLC-11 F-Type Male Compression Connector - RG11 | ShowMeCables.com
F-Type Male Crimp Connector - RG11 Plenum | PL11CS | ShowMeCables.com
http://www.showmecables.com/category/F-Connectors.aspx?q=&pg=1&ps=15&fq={attr_cabletype_sm:RG-11}
   / Cell Signal Boosters #119
Yes you the phone will switch from booster to tower. You will not notice it. We have Wilson booster in the house and direct connection outside. Difference is only signal strength. Almost full in the house and one or two bars outside.
   / Cell Signal Boosters #120
When the switch is made mid-call does the call stay connected? And if so, in both instances? Both moving from the inside to the outside of coverage and from the outside to the inside cell?
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2012 Chevrolet Equinox LT SUV (A50324)
2012 Chevrolet...
