Tip for handling filled tires alone please
   / Tip for handling filled tires alone please #61
It's not too bad if you're careful. Jack up tractor to barely remove tire from ground, and walk tire off the studs. Keep tire vertical at all times. If tire starts to fall, let it go and don't try to stop it. When reinstalling tire, I like to get a stud at 12:00. Walk tire in place and get 12:00 stud started in wheel hole. Start a lug nut, and jack tractor up more. In my experience, this caused the wheel to drop in place.
   / Tip for handling filled tires alone please #63
I remove my fenders ( 5 mins) then use an engine hoist and a rugged strap. Tighten the strap as tight as you dare so the crane does not move away from the tire itself. Remove lugs and let the tire settle on the frame of the engine hoist. I've had them off like 5 times, no issues. They are loaded 17.4-24L.
Fred
Fred
:thumbsup:
Thats my plan
Had some free time today so I got the garage cleaned out and started on the tractor. I know getting them off is the easy part but it really was pretty easy and straight forward.
And yes I know 3 jack stands is overkill.
Hopefully, putting them back on is also anticlimactic.
   / Tip for handling filled tires alone please #66
   / Tip for handling filled tires alone please #67
You can't have too many jack stands. Good job!
According to my operator's manual you are only suposed to jack from the center (drawbar housing) after "securing the front axle so it can not turn).
Since there is no "front axle" that turns/pivots and I did not know how to fix both front wheels..... Hence three stands.
   / Tip for handling filled tires alone please #70
2019 FORD F-250 XL CREW CAB SERVICE TRUCK (A54756)
2019 FORD F-250 XL...
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
TEST YOUR BID BUTTON! (A54757)
TEST YOUR BID...
2015 Nissan Sentra Sedan (A55758)
2015 Nissan Sentra...
2008 OSHKOSH FRONT DISCHARGE CONCRETE TRUCK (A54313)
2008 OSHKOSH FRONT...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
