More M59 repair fun.
   / More M59 repair fun.
As far as beating this machine goes, I don't ram or beat rock with this. I've never ran any attachments front or back. I do try to move the most material and can with the front. Dirt being the heaviest and the m59 struggles with heaping scoops. It's been dry and I was pushing manure and dirt and back dragging dirt where the cows stomp it during winter. That in itself is very hard on front as far as it vibrating and slapping back and forth on the pins. That's when this one broke. The other broke couple months ago. Both snapped right at the grease groove.
   / More M59 repair fun. #22
Hershey, I've been looking at those pictures and at my own M59 and still don't haven't come up with any explanations that satisfy me.
For those that don't know me, I'm a welder and machinist as well as an mech. eng., and spent a lifetime designing equipment of all types. Still do a bit of it in retirement. And I have the same tractor. Mine is also a 2008 with similar hours. It hasn't been totally problem free but darn near. I also use mine reasonably hard and sure haven't had anything like the problems that Herseyfarm has had.
A couple of things bother me about these pins. Yes, I know from other conversations that Hersey beats his machines hard. We've talked about that before. But even so, there just isn't any easy way to get a shearing stress onto the center of that pin - especially when there's a locking bolt still in place that prevents the pin from sliding laterally.... And what with the decent geometry and bulky end support it is equally hard to see how the pin break could be deflection induced either. And the other bother is that you say this wasn't the first pin you've had break. Hmm....Have you checked all the other pins on the machine? Of course once that pin did break then things could progress just as you said - your sequence sounds reasonable to me - what with the outer half of the pin working it's way out and once that happens the off-center push bending the ear until the hose failed. But trying to see how to initially get enough stress on center of the pin to start the sequence is the problem I'm having.
It's sure sounding like it started as a pin material problem. And that's surprising because Japanese steel is generally right there with the world's best. I assume that the pins are hardened or plated at some point...could that be a clue? Of course there are ways to check where and roughly why a fracture starts. Doing that formally is likely to be more expensive than this relatively inexpensive repair, but any metallurgist and most mechanics who have a 50x microscope and a few chemicals can tell you a lot about a break like this.
For my part, I'm sure going to pull the pins on my M59 and see how they look before the season starts. And I'm going to talk with the guy that owns the local cylinder fab shop to see if I've missed considering something obvious.... then I'm going to sit down and do some more thinking.
I'll not condemn the M59 or it's loader design because of this, but will certainly check mine carefully.
Oh, I forgot to ask; do you use any other buckets or QA bucket attachements on your M59? Is there any missing info there?
Thanks,
rScotty
Rscotty
While some equipment pins are hardened or hardfaced, the Kubota pins are plain carbon steel. Cross holes drilled in pins however especially if the holes are not chamfered nicely are excellent stress risers. I'd chamfer all pin x-holes before reinstall.
   / More M59 repair fun. #23
Rscotty
This will not be enuf. Regardless of blending, as you suggest, the weak area will still be at the center and the cross drilled hole will still be there to further accentuate the weakness and will have sharp edges that you cant get to. Cracking will initiate at those edges. Even the orientation of the cross hole relative to loading direction, and depth of the center hole wrt the cross drilling point will affect. ... Theres lots of optimization do do and it would all help. The time to do that is if there were no design choice in the lube matter. Putting a grease zerk on the collar and using solid pins is a straightforward cure.
   / More M59 repair fun. #24
Of course you could pay a visit to your local heat treater and have them normailzed. It's not expensive.
well, all back together and ready for action. I did check my pressure and at idle I'm at 2600psi and 2800psi at 2500rpm's.
   / More M59 repair fun. #26
Well, I'll go with your idea about stress risers. It makes a good working hypothesis. Certainly I don't have a better idea and am just now beginning to look at some of the details of the design. I still think that a close look at the broken pins might tell why they failed. What did you see looking at the three pin failures on your 7520?
Frankly I never paid much attention to the pins on the loader and backhoe before. But after taking a closer look at my M59 this afternoon it looks as though all of the pins on the loader and backhoe are made using that same basic design. It'll be interesting to see what I find when I pull a couple of them.
rScotty.
   / More M59 repair fun. #27
Best to check the pins on the other end of each loader arm before calling it done.
good luck,
rScotty
   / More M59 repair fun. #28
rScotty.
Well, on checking I was wrong on the number. ... I have 4 broken pins at the groove and one still in one piece - altho I replaced 6. :confused2: Something is misplaced?
,,,,,,Anyway the pin that is still whole is cracked nearly all the way around the groove - how deeply i dont know. The crack goes thru the 1/2 cross drilling hole. All the pins at the implement end are now solid. The base ends of the curl and lift cylinders still have grooved pins. Id better check them. The tractor has ~ 1500 hrs; many of them hard loader time.
   / More M59 repair fun. #29
When you replaced the pins on the Mahindra what did you use? Did you lathe some up or find a size that worked? Have you compared the pins on the Mahindra with similar pins on your Kubotas?
Apologies in advance for pelting you with questions, but my curiosity is up now, and will probably stay that way until we know a lot more about the design and materials used in these pins. The problem with trying to figure out a fix is that pins could could look very similar and not even be close to being similar in performance and material.
rScotty
Out of curiosity what would you expect these pins to be made out of? Like a 4140 or 4150, same as gun barrels? And I guess the chrome finish is like an acid treatment or nickel?
   / More M59 repair fun. #31
I suspect Kubota pins are plain vanilla carbon steel with a zinc or cadmium plate, 1020 bar or 12L14 free machining.
I'd be surprised if they were a Chrome moly. This is Ag stuff, that is their mentality.
Now if I were designing (using FEA of course) my super tractor, I'd have oversized S7 tool steel pins, HT and tempered with a Laser applied Nickel cobalt ally facing riding in a Garlock GGB maintenance-free bearings shells with grease seals fed by an automatic grease system. Ta Da!
   / More M59 repair fun. #32
rScotty
This specialness in the pin is all done for convenience in lubrication. To provide this convenience the pin is compromised in the worst possible way. 1st, to do this at all invites copying because every greaser likes it. There is demand even in the face of seemingly random failure. By physics the design is unsound. By physics also, refinements can be incorporated to alleviate the unsoundness. However the fundamental modification is inherently bad and its unsound nature cannot be eliminated. So, since we have the motive to "copy" we open the likelihood of bad copies. They all will last for awhile; add strength blending, material and post fabrication sophistication, and then pure beef and they last longer. One may even think the problem is overcome. ... Well maybe - but at extreme comparative cost to simply using a solid pin.
,,,,Or maybe, right at the point the problem is "overcome" an antiwear plating is added. These are harder and more brittle than the pin. That stress riser still lurks inherent in the design. The parent metal by virtue of the augmenting refinements has been doing ok. Now tho it has a hard brittle plating which cracks and serves to start a crack in the parent metal. Hersheyfarm - IF your chrome or nickel plating extends across the groove it is a contributor to the failure. - After all this work to make inherently sabotaged pins function. - As you know, the true cost of your pin failure is huge compared to the still faulty replacement pin.
,,,,rScotty Yes, I have compared. ... The L2550 uses 1" pins, some of them drilled. They may or may not be grooved. The L3450 has a WOODS loader. It uses 1.25" solid pins. Huge in context.
-- The Mahindra, a monster by comparison, uses 1.125" Gr5 bolt blanks for pins - some drilled and grooved. This represents one example of a bad copy. ... The fact that 1-1/8 solid is plenty strong does not extrapolate to success on an equal pin having just a tiny bit of metal removed at the most strategic sabotage point. I used the undrilled variety supplied by the mfg for other loader pivots to replace all the drilled pins on the SK carrier. I would like to have gone to a larger pin to increase bearing surface as well, but that is a lot more difficult. They too would have to be solid.
Bolt blanks tend to be expensive so Iv bought some loong 1-1/8 Gr8 bolts so I can use the shank if any more of the drilled pins fail. The long gr8 are cheaper than the replacement gr5 pins from Mahindra.
   / More M59 repair fun. #33
You really can fault Kubota for using mild steel in the pins, be it would be nice if it were normalized.
See, Mild steel bends, alot, before it breaks.
X drilled holes in mild steel have less stress concentration factor, are cheap to make, yada yada.
The simple fix is use the bigger pin and more bearing area.
and X holes and drilled thru at the ends are nice, given, but don not help the pins stay a single piece.
   / More M59 repair fun. #34
   / More M59 repair fun. #35
   / More M59 repair fun. #36
Triple yes. ... It would be interesting to design a reasonable sized drilled and grooved pin for an application that HAD to use that greasing method. I have some ideas that would not add [much] cost. The big question is whether the sensitization of the area can be handled enuf so the pin can wear out rather than break. :eek:
....Its not like the center is too weak. Its the leverage of the rest of the bowing pin on a concentrated slightly reduced area. Fatigue.
   / More M59 repair fun. #37
One, they are zinc irridite plated and two, the simple answer is to make replacements from certified Grade 5 capscrews (not Chi-com grade 5, domestic grade 5). If you use a Grade 5 capscrew, it's already heat treated and normalized.
You don't want a Grade 8. You want a Grade 5 or an A-325 because you need the elongation prior to fracture. Grade 8 will shear, a Grade 5 will elongate.
Simple matter to lop the hex head off the proper diameter shank and install, putting alemite fittings in the cross tubes instead of drilling and cross drilling the pins themselves.
Never had an issue with mine in 10 years.
   / More M59 repair fun. #38
Not to happy with Kubota pricing right now, see Posts #15 & 16
http://www.tractorbynet.com/forums/...m59-front-drive-shaft-leak-2.html#post4420381
Kubota should spend a little less on advertising and take care of your problem
This is a design miscalculation of possible loads on the pin or a materials defect. The repair should be on Kubota's nickel. The engineer(s) who designed this disaster should hand carry the repair parts to you.
PS this is not Photo-Shopped
Not sure what you are trying to show with your picture? If it's the fact that you are lifting the tractor off the ground with your backhoe I hate to tell you but I can easily lift my 580k off the ground of I bet the bucket under a solid root or rock. I have to be careful because if it suddenly lets loose it will slam back down on the ground. I tried to fill the bucket with dirt but all I did was peal apart the backhoe bucket like a pull tab on an old beer can. $350 for a used replacement bucket was all I needed to learn to live within the limits of the machine.
I think you'll find that Kubota uses mild steel simply because they want the pin to wear since it's the easiest part to replace. I replacing the right pin when the left pin would probably been a good idea. I think I would remove all the loader pins and inspect each one closely.
   / More M59 repair fun. #39
I ignored that post and chalked that one up to 'stupid is as stupid does'.:D
   / More M59 repair fun. #40
Whoa! ... Perhaps we need a little background on material. - All material, steel included, acts like a spring until it doesnt. That is to say it flexes when it is loaded. The more load the more flex. But until the flex exceeds the elastic limit of the material the piece will return to its original shape after the load is released. If instead load continues to increase you finally reach a point that the metal "gives" [yields plasticly] and begins to bend. You never want to reach this point in a loader pin because they see repeated load reversals in their use and will bend back and forth.
A stronger pin is a better spring. A pin of the same size has almost exactly the same stiffness as the weaker steel; flexing the same per given load. It is stronger because at the point the weak pin is damaged [bends] the strong pin is still just flexing. ... So you want the pin made of the stronger steel if ample sized pins arent used. The stronger metal is undamaged by the load and will last. ... Talking equal size; a Gr5 will last where a grade 3 wont, and a Gr8 will last where the Gr5 wont. But, since theres no difference in the stiffness theyll all act the same in the assembly seeing the Gr3 load.
All pins bow in response to load. Thats the problem with using a small pinned assembly and upgrading to a strong alloy pin to make it survive. The strong alloy "makes" its strength by being able to withstand higher deflection without bending. The strong alloy bows back and forth - itself happily enuf, but slowly wallowing out the ends of the crosstube bore because of the intense forces out near the shear point. The strong solid pin happily accommodates the bellmouth by bowing a little further. The ones that are grooved at the center start to die. That bowing is concentrated there by the full cross section on each side, finally exceeding the elastic limit of the surface metal in the groove. It cracks at the groove - a cross hole accentuates the start of cracking. With equal loading the Gr8 would have gone a little longer due to its higher elastic limit but as the bellmouth worsened ... you get the idea.
Since stiffness goes as the cube of thickness [in this case diameter roughly], big pins are the answer - absolutely if drilled and grooved. There is no point paying for high strength steel because bowing is so miniscule as to pose no fatigue threat. The pivot remains happy thru a long life.
,,, If a maker goes the small strong pin route to support high load theyd better use solid pins. Still the relatively great bowing under high load will wear/deform the joint much faster.
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
2020 Chevy Silverado (A56438)
2020 Chevy...
2023 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2023 CATERPILLAR...
John Deere 1025R (A53317)
John Deere 1025R...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
