Loader Hydro in and out side help.
/ Hydro in and out side help. #1
alpinebigfoot
starrucca, PA
Yanmar 186d
Which one is in ? 186d. Have to get this right or blow the valve! Thanks loader install coming soon.
/ Hydro in and out side help. #2
I can tell you the high pressure line from the pump comes in on the side next to the bottom hose. Therefore I would think that would be the high pressure leaving the block. Don't sue if I'm wrong.
I am thinking these both are the same. The small line goes into this. On the other side of the tractor there is one connector. I have a in and out on this loader don't want to blow it up !
/ Hydro in and out side help. #4
Where do the two hoses go at present?
Those two in the picture are the same its just a loop that connects both
/ Hydro in and out side help. #6
Ok, I am catching up now. that is where your snowblower hooked up. Which one of those lines went to the inlet (pressure) side of the snowblower?
I don't remember. I took the connectors off to put on this loop.
/ Hydro in and out side help. #8
I stick with my first answer, the bottom hose would be the high pressure returning through the top hose. If you want to make double sure then disconnect the hoses, do whatever is neccesary to open both ends of the hoses, then with throttle closed, bump the engine over and see where the fluid comes out. That will be the high pressure. Just don't do it with no place for fluid to go. You shouldn't lose more than a cup of fluid. Hope this makes sense.
Wouldn't I just plug them in there at the loop? That small line from the pump goes into the distribution block to the two connectors.
/ Hydro in and out side help. #11
That block also has an opening into the 3 point control. Yes, I know the small line from the pump goes into the block. I stated that in my first post.
I don't understand, plug them in there at the loop? Plug what in there?
Never mind I think i got you. Just take both the quick disconnects off, bump the key and the oil will only come out of one of those. That will be the in to the loader and the other will be the return. Right?
/ Hydro in and out side help. #13
You got it. :thumbsup:
I have no idea I bought it like that. I got the loader working now. It was easy to do just didn't want to mess it up. Thanks for all the help! I started another post with the loader install.
32" Mini Sifting Bucket  (A62679)
32" Mini Sifting...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2020 Pitts Chip Trailer P16316 (A62613)
2020 Pitts Chip...
