Seeders No-tlll drill vs other attachments for seeding
   / No-tlll drill vs other attachments for seeding #1
cptkel
Mercersburg, PA
Kubota L3901
Hello all
This is my first post here.
I recently purchased a Kubota L3901. I am seeking advice on an attachment I could use for seeding. I would like to sow a mix consisting of clover, grasses, and some pasture vegetables (daikon, turnips, herbs, etc). I would like to do this on some of my 12.5 acres. I am leaning towards a no-till drill. Currently, I have a stand of old foxtail straw, chickweeds, and other pasture weeds.
Is there a drill that my tractor could handle? If not, could you offer some suggestions of how I could go about this with no or minimal tillage/plowing?
Thanks!
   / No-tlll drill vs other attachments for seeding #2
Try looking at seeders from Brillion. They make small to large grass seeders. I am not familiar with the seeding depth of some of the seeds you mention but grass seed needs to be planted shallow. I was recently reading a grass seed planting depth chart (because grass seed isn't cheap) and 1/4" to 1/2" was optimal. When the seed was planted at 2" germination was 19%, rising to about 65% at 1" and 93% in the 1/4 to 1/2" range. I think Brillion had a seeder with 2 rollers, the first to break up and flatten the soil and the rear to tamp the soil around the seed placed at the shallow depth. I remember seeing some short 3 point seeders at auctions and dealers.
   / No-tlll drill vs other attachments for seeding #3
I've been thinking of one of these Zip Seeders for a couple of years. All seem to be too far away for me to go look at before buying. I missed one last year withing driving distance by a few hours on CL. This looks like a decent one in VA. Garden Seeder
   / No-tlll drill vs other attachments for seeding #4
Talk with your local County Extension before you purchase a drill. Often, they have one or have access to one and will help you to insure you are optimizing your choices on both seed and planting. Also, your local Co-op or seed dealer will often have one to rent or free if you purchase seed from them.
   / No-tlll drill vs other attachments for seeding #5
No-till drills plant seed in rows.
A planter like the Brillion plants seed in a solid stand. However, you need to prepare the soil by plowing, discing and running a cultipacker over the soil to bust up the clods and smooth the field.
I'd mow the field as short as possible. Plow it with a heavy disc with an attached drag harrow. And then use a broadcast spreader on the 3-point hitch to plant the field. This will give you a solid stand.
Good luck
   / No-tlll drill vs other attachments for seeding #6
If you'd have posted this back the first part of Feb., with your location, you could have utilized Frost Seeding. I've done it several times with very good success..!!
   / No-tlll drill vs other attachments for seeding #7
Good luck
I agree ^^^^
On a small space of 12 acres or less I would plow or till it and broadcast seed. You can use the broadcast seeder to put out fertilizer as needed later on. I would hesitate to buy a drill for a one time planting of a small plot.
   / No-tlll drill vs other attachments for seeding #8
Basic no-till drills will have no more that about 130-190 lbs of pressure/opener available to them. True no-till drills will have over 400 lbs available to them. Decent plain jane disk drills will have as much as 120-160 lbs of opener pressure. So don't be lured by the no-till advertising it is very possible to accomplish the same thing with just a drill, assuming you are not planting in the pavement. I agree w/ dagnatron, many extension agencies will have small drills available to rent and are typically pretty reasonable. Or like jenkinsph and flusher says, prepare the seedbed and broadcast it.
   / No-tlll drill vs other attachments for seeding #9
Never heard of this. What do you do?
I have actually been told by several local farmers to try the ag extension office. I have called once, but they said the budget didn't allow for it in my county.
I thought broadcasting had a poor success rate? This is simply scattering seed over the ground, right?
I really would rather not buy a no-till, not to mention I don't think my tractor could handle most. What would be the difference between a no-till and a simple drill be? I don't have any plows or tillers yet, either.
Thanks for advice so far!
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2010 INTERNATIONAL SF637 ROLL OFF TRUCK (A55745)
2010 INTERNATIONAL...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
Husqvarna Z 248F 48in Zero Turn Mower (A55851)
Husqvarna Z 248F...
2018 FORD F-350 (A55745)
2018 FORD F-350...
