B3350
/ B3350 #1
Nickba1
Rice Lake, WI
JD 3046r
I'm looking to upgrade from my B3300SU to one like it with a cab. Logic brings me to the B3350 since the 33HP suits my needs. Of course I'm moving into the Tier 4 issues. Some reports suggest they have been fixed. I have been looking at a used 2014 3350 with 28 hours in good shape at $25,500 vs a new one similarly equipped at $29,000. There are about three months left on the used warranty. I'm told it works fine with all of the regen issues resolved. Do those prices sound about right?
/ B3350 #2
That model has appeared quite a few time with many issues here on TBN. I would run not walk away from that model, Kubota I believe is still offering 0% for 60 months,maybe the L3200 or equivalent model would be a better choice for you?
DevilDog
/ B3350 #4
Devildog, can you elaborate on the issues other than the regen?
/ B3350
Devil dog, thanks. Even with the regen fixed it seems like there are lots of remaining issues around it. Of course there are probably many more that aren't having problems. i still like the size of my B3300 over the larger models. Maybe I'll take a look at the JD 3033R since I'd really like to have a cab.
/ B3350 #6
Luke's Sorry I wasn't as clear spoken as I thought, the only issues that I remember were the regen ones and if my memory is correct starting issues after regen? there were quite a few with a maybe Kubota buying the B3350 back from someone who had tractor in shop for long time.
DevilDog
/ B3350 #7
No need to apologize I just figured I'd missed the other stuff.
/ B3350 #9
I spoke to a dealer about the B3350 for a bit about the regen issues. Here in the northeast the machines would never get hot enough to enter into regen, the problem mostly presented itself in the colder months from what he said. So the DPF would clog and cause all sorts of issues. Apparently there are some factory updates that cause the machines to run a bit warmer now and get up to temp to allow the regen to occur.
/ B3350 #10
Thanks good information, I live in the deep south we don't get much cold weather, I hope they have the regen problem fixed, so far my B 3350 tractor has been perfect
/ B3350 #11
No pictures, it didn't happen. ;)
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2023 Peterbilt 567...
2016 KUBOTA SVL95-2S SKID STEER (A62129)
2016 KUBOTA...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
2017 PETRBILT 389 6X4  T/A SLEEPER TRUCK TRACTOR (A59908)
2017 PETRBILT 389...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
UNUSED KUBOTA BT2914-24" PIN ON EXCAVATOR BKT (A62130)
UNUSED KUBOTA...
