Front-End Loader Digging Attachment
/ Digging Attachment #1
LouieJunior
Moline, Illinois
JD4052R Open Station
I am doing battle with the beavers every weekend. They are building a small dam at the end of a culvert and flooding dozens of acres. I have cleared the blockage countless times -- but they don't give up (and there are many of them). The clearing is done by hand, since my front loader can't quite reach the dam. A backhoe would be perfect, but I have no other use for one and would cost $7K or so.
I am wondering about a loader mounted front hoe. I have 3rd function ability. Searching, I only see skid steer attachments. Titan has one. I suppose it is too much stress for a loader -- but I wouldn't he digging up stumps with it. Any thoughts or ideas?
/ Digging Attachment #3
I really don't know much about them but you may also need to check and see if you have enough GPM to run one (no idea - just a thought). I also agree that you may need to be really careful as that would be a putting a lot of stress on the front loader. If you decide to give it a try watch craigslist and local auctions. Around here you see them fairly often. One like that (no thumb however) sold for $300ish last year at an auction I was at.
Would it be possible to rent a mini Ex for the day and clear it all out, then dig out/move dirt so you could get in there with the tractor or make it harder for the beavers? - Around here a mini Ex is under $300 for 8 hrs)
Good luck!
/ Digging Attachment #4
I am wondering about a loader mounted front hoe. I have 3rd function ability. I suppose it is too much stress for a loader -- but I wouldn't he digging up stumps with it.
Too much leverage working against the loader.
I second Steve; your best option is eradication via trapping.
/ Digging Attachment #5
You'll never win.
Were it a wide dam you could breech it and lay stove pipe in bottom with multiple entry points.
The rodents then repair the dam but water continues to escape via the pipe. It works!
Other than that eradication is the only answer if laws allow it.
In Canada beaver are 'protected species' with severe fines, a law that should be rescinded as they multiply at a rapid rate.*
Back when the pelts were very profitable but Brigitte put a stop to that and decimated an entire industry. (even today the British palace guards wear 'faux fur' hats.)
*they are merely a large rodent.
Here are some dam pictures! 20160403_105521.jpg20160402_125154.jpg20160402_122027.jpg20160402_122014.jpg
I completely removed the blockage on Saturday morning and on Sunday morning it was back -- and even bigger!
/ Digging Attachment #8
They are monsters! It's too bad that we can't find a way to make them work for us instead of against us.
/ Digging Attachment #9
Beavers have all day everyday to make a dam. Best option for you is trapping.
/ Digging Attachment #10
This sounds like a perfect situation for the use of dynamite. Check with your county agent and find out what is required. Boom!
/ Digging Attachment #11
Or you could decide that you actually want a pond in that location and suddenly you no longer have a problem...:cool2:
/ Digging Attachment #12
Here are some dam pictures! <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=463460"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=463461"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=463462"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=463463"/> I completely removed the blockage on Saturday morning and on Sunday morning it was back -- and even bigger!
Have they flooded that whole area. That looks like a lot of water from just that small dam.
/ Digging Attachment #13
From November 2004, beavers dammed the pond spillway. I had some flexible drain pipe, so I fastened them together, and a weight on one end and put them over the beaver dam.
Two days later, as long as the weighted ends were under water, it would siphon.
A week later, they have added more sticks, but water is still siphoning. :thumbsup:
A little ice on the pond at the end of December, but water is still flowing. The beavers gave up and moved on, some time after this picture was taken.
/ Digging Attachment #16
I had the same problem when I first purchased my 160 acre property.....the "beavs" had gone unchecked for a few decades and as a result built two super-dams that subsequently flooded about 10-15 acres of farmland....it was basically a lake...great for duck and goose hunting but it actually cut me off from accessing about 30 acres of prime wooded and hunting land...essentially the back 3rd of the property....also, they were killing scores of huge viable trees just to get at the top branches for food....the rest of the tree just rots.....what they had actually dammed was a municipal drain that runs right down my property.....the drain superintendent got involved and the bottom line is that they encourage land owners to take action on their own property to take care of the problem by "relocation" of the varmints....especially in my case as this was also causing other problems upstream on other properties.....so the green light was given...it was spring-time....we proceeded to manually break down a 5-6 foot opening at mid-point of the dam, enough to cause a major drainage of the flooded area...this worked great to bring the water level down...of course as most of us who have dealt with a beaver problem before know, these critters are not only destructive but also industrious little buggers....the first thing that happens is the "re-construction crew" shows up around 7 PM to fix the leak....the dispatch crew (that's us) wait for them to arrive and proceed to send them to heaven....accelerated lead poisoning.....about 20 beavers over the span of about 2 weeks.....any remaining beavers got the hint and left, never to return....the entire area was drained, dried and is now green again....trapping works too but it's a lengthy and less effective process than a .22 mag. Unless you do it this way, as PILOON said, you'll never win....in the province of Ontario you don't need a permit to scare away, capture or kill most wild animals, if the animal is causing damage to your property, unless the animal is on the endangered or threatened species list....beavers are not on the list for obvious reasons...overpopulation....some people like having beavers around.....I don't.....this is the way the landowners in my neck of the woods take care of the problem.
/ Digging Attachment #17
I hear beaver is delicious
/ Digging Attachment #18
I worked for a farmer that was having issues with beavers in a major drainage area here . He got a phone number for a removal service . Two young guys show up in longjohns , t-shirts and tennis shoes . Mind you this is January in Il . They waded into the water with homemade fertilizer bombs and destroyed 3 or 4 dams and hutches , very impressive . When finished the boss asked if they would take a good check . The kid looked him square in the face and said I hope you don't write me a bad one ! The boss went lickety split to town and got cash . We laughed about that for a long time . And the beavers were gone .
It is a small marsh, normally -- but the beavers can flood a lot of acreage by blocking a single culvert. Right now, the water is running over the road on the dyke and standing in a few fields. The beavers are also benefiting from frequent spring showers. They can build a tiny six foot dam and the water has no where to go.
I have a flashboard riser on my tile so I can block the flow in the autumn -- but the beavers have taken over my control.
2012 Keystone Alpine 3500RE 39ft. T/A 5th Wheel Travel Trailer (A61569)
2012 Keystone...
2014 FREIGHTLINER SPRINTER 2500 4X2 CARGO VAN (A59909)
2014 FREIGHTLINER...
36 Gallon RV Septic Caddy (A61166)
36 Gallon RV...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2013 Ford F-750...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2012 Dodge Charger Sedan (A61569)
2012 Dodge Charger...
