Getting manure to slide out of a dump trailer
   / Getting manure to slide out of a dump trailer
If you have a decent loader, forget the dump trailer feature, pick up the trailer and dump the load by rolling it over. No big deal.
So out of curiosity how would you go about flipping a 7x20 gooseneck dump trailer with 4 ft sides? trailer weighs around 6k and holds 20 yards of material.
   / Getting manure to slide out of a dump trailer #32
   / Getting manure to slide out of a dump trailer #33
Just Flip her over. Same way you'd work on your truck! Dynalift Kens Truck B Aug 13 1994.jpg
   / Getting manure to slide out of a dump trailer #34
Start with a clean trailer.
Get a gallon of old motor oil and an old broom. Paint the motor oil on the bottom and sides of the trailer using the broom like a giant paintbrush,
Do not let any of the eco-weenies see you doing this. Off course they may have a heart attack and not bother you again...
   / Getting manure to slide out of a dump trailer #35
Never mind the Eco-weenies, what do you want the manure for? If it's for growing things, why maim them at the same time? Just curious.
Jim
   / Getting manure to slide out of a dump trailer #36
We have a 14 foot Load Trail dump trailer. We use a plastic plywood comes in 4x8 sheets. 1/2 or 3/4. We used 1/2. Tougher stuff. Have had it in the trailer 8 years. We haul every thing from stone to tractors to manure, round bales. It always dumps clean.
This is the product we used.
Agricultural: Densilite XP Plastic Sheets | Plastruct Polyzone - Polyzone Plastic Solutions
Do you buy it direct or do you have a local reseller? How much does it cost? I presume you bolt it to the trailer floor. How about the sides of the trailer walls?
   / Getting manure to slide out of a dump trailer #37
The trailer you show in that link, just doesnt have enough dump angle. Ag trailers have 70 degree dump angle, not 45... Even with sticky clay you'd have trouble...
...even though fresh straw muck usually slides out before it hits 45 degrees..
   / Getting manure to slide out of a dump trailer #38
Fury, I have bought it locally, the 3/4 is about $85 a 4x8 sheet. I picked up 20 sheets down Indiana / Michigan boarder as well!
   / Getting manure to slide out of a dump trailer #39
There is a bunch of good places around there. Drive a 1 1/2hr to get Dimond plate cause it's so cheap
2022 PETERBILT PB337 DUMP TRUCK (A52706)
2022 PETERBILT...
2013 ISUZU NPR STAKE BODY TRUCK (A56138)
2013 ISUZU NPR...
2010 INTERNATIONAL DURASTAR 4300 CHEMICAL TRUCK (A55745)
2010 INTERNATIONAL...
2018 CATERPILLAR 908M LOADER (A52706)
2018 CATERPILLAR...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
