Problem with wiring
/ Problem with wiring #1
Kubota brent
Kearneysville,wv
2004. Bx22. Kubota
I have bx22 .if you move wires under gas tank tractor will start,but if I take my hand off switch it shuts off.any help
/ Problem with wiring #2
Any time you move wires and something happens you have a short or bad connection in that area. You will need to track down the offending wire and repair/replace as needed. You may have more than one problem so start with the easiest first.
Start with the safety switches.
/ Problem with wiring #4
More likely an intermittent open.
Shorts are when wires connect or short to ground that aren't supposed to or when they aren't supposed to as in a short circuit, many times resulting in letting the magic smoke escape.
Probably where the wiring connects to the key switch in this example. Always look for opens at the connecting ends and terminals first as it's usually a loose screw or something.
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
(10) New CATERPILLAR Keys (A65579)
(10) New...
1987 GMC C7000 Fire Truck, VIN # 1GDM7D1G3HV526472 (A65563)
1987 GMC C7000...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
2012 Audi Q5 3.2 Quattro Triptronic (A62679)
2012 Audi Q5 3.2...
Dueling Tree (A65640)
