Everything Attachments Landscape Rake
/ Everything Attachments Landscape Rake #21
Any response from this? I would like an answer rather just just posting videos.
/ Everything Attachments Landscape Rake #22
They contacted me by pm almost immediately after my post. Tines are going to bend and break no matter what kind you get. Some may late longer than others. I may going to show my brace modification to them.
I do look at frontier and Taylor way rakes prior to get the EA and neither of the ones I looked at where as heavy.
/ Everything Attachments Landscape Rake #23
I guess they forgot to send me a private message. It would be nice if they explained it in the thread if people are having problems with thier products.
/ Everything Attachments Landscape Rake #24
Am I missing something or did you only bend some tines?
I've read a lot of reviews from people that have the ETA Landscape Rake. Pretty sure it would be pretty easy to destroy any landscape rake if not doing what they are designed for. I don't have a problem switching out implements if confronted with something that is not meant to be done with a landscape rake (like a root grapple).
Not saying no one had a legitimate problem, but unlike some other implements, pretty sure you would have to use any manufacturers landscape rake with due care.
/ Everything Attachments Landscape Rake #26
I also have the 84" extreme- whatever, ETA rake and just broke my first tine in two years of sometimes rough work clearing my property, grading, etc. I have hooked the tines on many a large rock or stump or hooked the end of the rake into a tree. All major grading was done with the ROBB, but also did a lot of the lighter grading with the rake since it does a good double duty job. And the wheels sure made the final grading far more successful that I would have been without them. Love the wheels. Just used them again tonight to rake some new gravel over fill I had rutted up with my 8000# truck after a large rain event.
Never a problem until two days ago when I broke my first tine. I felt fortunate. And considering what I was doing when the tine broke, I probably finally backed up over/into something it hooked on and finally broke. No worries. I just replaced it with one of the four spares I purchased when I got the rake. And have three left. To me broken tines on occasion are just a part of the beast- assuming there is not a factory defect.
I am seriously considering a post hole digger and need a more heavy duty one that what is typically available on CL, TSC, etc. in my heavy, very rocky (small boulders) clay. I am seriously considering the ETA 6900HD PHD or the SpeeCo HD unit. The performance of my ETA rake is leading me towards the ETA PHD.
/ Everything Attachments Landscape Rake #27
I've had an EA rake now going on three years, I use it moderately hard without any broken tines as of yet. I have one that is slightly bent about a half inch or so, wouldn't hesitate to buy again.
/ Everything Attachments Landscape Rake #28
Well, I broke two more tines tonight and significantly bent a third one. So after two years I broke three tines and bent one tine, all very recently. All damage was my fault as tonight I took that 7' rake into a wooded area that was not cleared to get at a pine tree that needed to be removed as it was standing where a 6 x 6 fence corner post needs to go. I remember going back and forth a few times digging out the tree and should have realized I was running the rake into a tree. So all of my spare tines are now gone and I need to order a few more.
BTW: I compared all tines on the rake- new and old and they are all shaped very similarly and all lay at the same height with the rake lowered to the ground (concrete). Meaning none bent from use, other than an insignificant amount, I imagine.
/ Everything Attachments Landscape Rake #29
Well, I broke two more tines tonight and significantly bent a third one. So after two years I broke three tines and bent one tine, all very recently. All damage was my fault as tonight I took that 7' rake into a wooded area that was not cleared to get at a pine tree that needed to be removed as it was standing where a 6 x 6 fence corner post needs to go. I remember going back and forth a few times digging out the tree and should have realized I was running the rake into a tree. So all of my spare tines are now gone and I need to order a few more. BTW: I compared all tines on the rake- new and old and they are all shaped very similarly and all lay at the same height with the rake lowered to the ground (concrete). Meaning none bent from use, other than an insignificant amount, I imagine.
Always seems to happen a few at the same time. Ha.
/ Everything Attachments Landscape Rake #30
This root ball rolled and tumbled. We did spring a tine, but much worse could happen from this sort of abuse. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=462712"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=462713"/>
This looks to be a bit extreme for a rake. To be honest my rake doesn't get used as often as it did back when I bought my first tractor. These days it's the grapple for something like this
/ Everything Attachments Landscape Rake #31
We like extreme! If you think that's extreme, here's the tacked hitch/tube for our Land Shark landscape rake and scrape blade.
Travis
/ Everything Attachments Landscape Rake #32
We like extreme! If you think that's extreme, here's the tacked hitch/tube for our Land Shark landscape rake and scrape blade. Travis <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=463053"/>
Wow looks sweet!
Reminds me of my servis blade
How big of stick, logs can a rake be used for? I wouldn't think logs but this could prove me wrong
/ Everything Attachments Landscape Rake #33
Wow looks sweet!
I do see the similarity.
Check out the videos/pics I posted on page 2 of this thread. Peanut, under Ted's direction, tried to break it using several techniques, including a log with the stump attached!
Travis
/ Everything Attachments Landscape Rake #34
I saw the photos and that's what sparked the thought of how big "should" these be used on. Obvious this was used as a stress test.
/ Everything Attachments Landscape Rake #35
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
