No drive from front axle
/ No drive from front axle #1
Grumps55
Devon, UK
Yanmar 276d
Hi
I've got a 276d with no output from the front axle! I have drive to the front diff and can see the pinion turning so I assume it is internal, Does any one have experience of this fault?
Regards Pete
/ No drive from front axle #2
has it ever worked ??? Does the shaft turn just not the front end ,or the shaft doesn't turn at all ?
/ No drive from front axle #3
It could be anywhere in the front wheel drive from the pinion/ring gear to either side having a bad gear or broken shaft. When either side fails you lose it all. I would jack it up, rotate by hand listening and feeling.
/ No drive from front axle #4
First thing to check is that the front drive shaft is still there - and that it is not stripped out on one end or the other
/ No drive from front axle #5
Some good advice.
/ No drive from front axle #6
Unless you have run it on jackstands all of those parts move just from the front wheels turning with the tractor.
/ No drive from front axle #7
agreed. could be a stripped spline, broke shaft, stripped hub, bad ring or pinion gear .
/ No drive from front axle #8
In some Yanmar made tractors use ball bearings in the front and rear of the front drive line couplers. Fairly easy to get to and service. Under the tractor, loosen the drive line cover clamps and slide them together. Put the tractor in neutral and disengage the 4WD. You should be able to examine the drive line couplings front and rear at this point and see if the drive line has engagement with both sides of the couplers. Many times, it's just needing a new set of drive balls and you are good to go. Others, the balls have stripped in the couplers and a new drive line is needed as well. Fine place to start troubleshooting the problem. If that isn't the problem, remove the drive line, engage the 4 WD and see if you have engagement at the rear coupler. ( do not start the tractor, do this by hand ) If you do, problem is in the front end and will get expensive quick. If you don't have engagement, it's a tractor split, that won't be fun either. Good luck,
Chris
Thanks guys for all your advice,I'll keep you posted.
Bobcat Turbo 873 Skid Steer (A62679)
Bobcat Turbo 873...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A65643)
2012 WESTERNSTAR...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
Lot of (18) Hedge / Black Locust Posts (A66408)
Lot of (18) Hedge...
John Deere 2840 Tractor (A64047)
John Deere 2840...
