Grapple Loader Hydraulics
/ Loader Hydraulics #1
Spiros
Bartlett, TN
Yanmar 2210, YM1900, 1963 Ford2000diesel, New HollandTC33
I have installed a loader on my TC33 and switched the relief/diverter manifold to supply said loader. It works great but my rear lift has ceased to operate.
Upon reading the manual, it states, the diverter valve in the 10 oclock position allows auxillary hydraulics to operate and in the 2 oclock position allows flow to the HPL. Will it not do both at the same time? What am I missing?
Thanks in advance,
Spiros
/ Loader Hydraulics #2
Thanks in advance,
Spiros
Hello Spiros,
You are not missing anything Spiro, your diverter valve can only
provide fluid power to one function of the tractor at a time.
Christos Anesti
/ Loader Hydraulics #4
You should be able to run both the loader and the three point. I expect the power beyond line from the loader valve is not going back to the correct port. You should post your question in the New Holland forum with some pictures of how your lines are connected so other TC33 owners can comment.
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
CAT R500/D9R Ripper Teeth(6) (A68134)
CAT R500/D9R...
3097 (A63117)
3097 (A63117)
X (A68191)
X (A68191)
