My Homestead in the making.....
   / My Homestead in the making..... #81
I think you need that ripper tooth we discussed.
   / My Homestead in the making..... #82
A very good example of why you should never cut down the tree before digging it out. I can take out an entire tree with my backhoe in ten minutes, but it takes hours to dig out a stump.
Make a video.
With these trees they are close to the house, I have never dug one out while still standing.
I had less than 2 feet of clearance if it fell the wrong way I would of been screwed, so it was roped and pulled down as I cut it to control landing. Had to pull both of them against their lean also.
Well, I'm done for a little while.
Busted a hydraulic line on the BH! Darn it! Was under pinning the stump and got it hooked on the root that I didn't see and put a small pin hole in it. So now it leaks.....UGH!
   / My Homestead in the making..... #87
Leave the stumps a lot longer for leverage. You are giving up a free built-in lever.... No reason to cut them that short, even next to a house.
Did some more work around the house.
Had to burn out the tap root on a Hickory stump! It was as big as my leg at 4-5 foot deep!
Pressure washed my deck, it was bad but looks much better now.
Dug out another stump next to driveway and now I can widen the driveway at the top of the hill and make the parking a little easier up there. Some the rocks I pulled out from around the stump were rather large! I plan to use the larger rocks as decorations and stuff around the house.
   / My Homestead in the making..... #89
Looking better every day. I love you random movie quote. Um..Hmm.
Slowly but it will get there sooner or later.
I was wondering when someone was going to notice my quote's, I have been changing them once a week or so. It's actually time to change it again now that I think about it.....Um...Hmm
2006 John Deere HPX Gator 4x4 Utility Cart (A55787)
2006 John Deere...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2023 BOBCAT E35 R2 SERIES EXCAVATOR (A52705)
2023 BOBCAT E35 R2...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2012 Ford Escape Limited SUV (A55758)
2012 Ford Escape...
