Hay Storage
/ Hay Storage #1
farmer2009
Elite Member
Western KY
Multiple
How are you guys storing your hay?
Currently mine just sits outside unprotected but I'm looking into getting some tarps and covering some of it. Might take a couple of years to get it all covered. I only string tie, no net wrap option.
/ Hay Storage #2
Keep it in this barn on a tarp. If I need more space I have a bigger barn. I realize many TBNers need much more storage space than this little barn. (21X36) But it works for me at this point. The big barn pictured in my avatar has much more space, but it's not needed yet.
/ Hay Storage #3
Poured a slab in the tractor shed and it takes up one bay... only 3 hay burners to feed so it works.
The horses out to pasture forage year round and do well... only provide water and a vet checks in on them every 3 months.
/ Hay Storage #4
If you use tarps you need to ventilate the area at the top of the tarp somehow. I had quite a bit of hay under them and due to condensation I lost the top layer. Also, make sure you stack the hay so that it sheds the rain.
/ Hay Storage
Yea. I need to store a lot more hay. I'm currently feeding about 175 4x5 round bales a winter. I have an old building that currently holds 12 bales. But if I rework some of it I think I can get that to 24.
/ Hay Storage
Hay will be stacked in either a 3 bale triangle or a 6 bale triangle. I plan on getting out today and seeing if my tractor will stack the 6. I know it will the 3. If not it'll just be more ammunition to convince the wife I also need a larger tractor.
What kind of bales did you loose? We are in a very humid and rainy area. 40+ inches a year. Most years get above 50. So condensation will be a concern but one I never thought of. My thoughts were to stack the hay all the way out to the ends of the tarps. Leaving them open.
/ Hay Storage #7
I store enough hay to get me to the next harvest. To keep my storage area convertible I do it this way. It is dirt floor. I have an area that is twelve by forty eight that I use for storing. I put down four by four and four by six lumber on the ground such that use then as "sleepers". On top of them I lay plywood sheets and scraps to make a false floor. I salt the the wood before we start stacking the hay.
As the winter wears on, into spring, I pull up the sleepers and plywood that is exposed and use that area to supplement more lambing pens. Right now, we have hay stacked in only a 12 by 12 area. I use pressure treated,douglas fir, or western red cedar for sleepers. They rarely rot as long as I clean them up from mud and store them to air dry for the next year. It works out real well for me. Mice have a good time underneath, but I don't have any condensation problems with the bottom layer at all as long as I salt the plywood. I hate screwing around with plastic and tarps.
/ Hay Storage #8
Well I stored round bales and square bales. The end I wasn't pulling from always got a lot of moisture from the driving rains (the piles were not orientated in the same directions). The round bales I didn't get in a true pyramid and the gaps between the top bales generally held some water. The square bales I had a grabber that stacked 10 bales at a time and I did 10 rows, 9 rows and 8 rows high in a pyramid. I always thought a tarp with a couple solar powered vents would be ideal along with some man made ventilation areas for the air to rise and escape underneath the tarp. Also, Make sure you have something to get the hay up off the ground. Hay will absolutely draw moisture if they are sat directly on the ground. This is especially true at the edges where the tarp drains all the water too. I used pallets set down and I didn't worry too much if I cracked a couple driving on them getting my hay off. One other tid-bit. It is very tempting to get the biggest tarp you can get your hands on. If you guys get any decent amount of snow, it can be a real challenge to get the tarp pulled back to expose the hay. Ice gathers in the low areas and snow builds up and you could easily end up having to shovel a foot of snow and 6" of ice before you can get the tarp moved. Don't ask me how i know. :D
/ Hay Storage #9
/ Hay Storage #10
/ Hay Storage #11
/ Hay Storage #12
We store most of our hay (4x6 rolls) under tarps. Stacking them 3, 2, 1 we get 60 bales per tarp. We do put the first stack on pallets. We run a piece of high tensile wire underneath the pallets (before building each stack) and use it to tie the side of the tarp down.
When folding the tarp around the ends, the center section of each of end stack is not fully covered so we do get some discoloration on a few bales, but no water damage. We have never had any problems with condensation.
The tarps are around $300 each and will last 3 or 4 years if taken care of.
/ Hay Storage
Thanks. Couple of questions.
What size tarps do you use?
I just checked and I can stack that third bale. So I'll be looking at a 3 2 1 setup. My measurements say I need 26 feet of width.
Where do you buy your tarps?
What tie down system do you use?
Seen one system that uses ratchet straps and ground anchors. Another that uses pins pressed into the bales them self.
I hate pallets for storing hay. I've just had some bad experiences with rot and flat tires as well as getting rid of them once they fall apart. Plan was for this first year I'd just set on the ground. Then maybe next year try to add a gravel pad. 3" of #4 Rock will do a lot of draining.
/ Hay Storage
Ok. Ok. I get your points. :). And people thought double post are bad. Laughing.
Plan are to keep a pyramid shape. We can see large snows and some try to stick around for while. So good points there. I do have the ability to store about 20 days worth of hay under roof so I could keep moving it to the roof structure during thaws. Plus whatever is sat out for the storm. I feed 6 bales at a time and that last me about 5 days. So I have some window of opportunity there to wait out snows.
/ Hay Storage #15
I don't know what happened earlier there. Do they give out stickers for scoring a triple post?? :D I couldn't login for a little bit either after I tried responding. I'm quite a bit farther north then you or agriman so blowing snow is always a concern and hence why i tried to keep as much of the hay covered as possible.
/ Hay Storage #16
Do the 6 bale triangle, 11 stacks deep.
Buy a "haystack" tarp at farm store, 23x48 feet
It perfectly covers 66 4x4 round bale (ends slightly open ) You can do 12 stacks deep if you don't want any end coverage.
I line stacks inline with prevailing wind (N here) and pull from south end. I fill shed from stacks, when shed empty, I move stack contents. Yes it's extra movement then just pulling direct from the stack, but you don't have to keep tying the tarp back every time you feed.
/ Hay Storage #17
Barn is best, but under good tarps works well too. Make sure it can ventilate some
However you need to get it Off The Ground no matter where you put it or what your flooring is. I pick up good wood pallets whenever I can. I look for the HD ones. All Free too. If they break, I just find another one and burn the old one. I learned the hard way on this my first season.
If you want to get pricey and have longer lasting pallets, look into the new plastic ones. Sometimes you can find them used and fairly cheap. Generally look someplace that get things in from overseas as wood is not allowed in some cases. Check around.
Hope this helps
/ Hay Storage #18
Find a place that uses coils of steel that are shipped in lying flat. They will have heavy duty pallets. the pallets may have some gaps between the boards but they will be good hardwood pallets that will last and will hold the weight of the hay. I find the ground moisture worse than the rain on a bale.
/ Hay Storage #19
This is why we went with concrete...
/ Hay Storage #20
Sorry, just got home (worked on the mud truck tonight). For some reason, I'm second guessing my memory on the size of the tarp. Let me double check it before I tell you something wrong.
I agree pallets are not always user friendly, but they do work. We stack in different locations every year depending on the pastures we are using, so pallets are the best option for us. We have found a good source for the blue pallets which are heavy duty and treated.
We lay out our pallets (one stack at a time) with a piece of high tenslie wire running underneath the pallets (with about 3' extra on each side). We usually place the wire under every other stack. Once the tarp is on, we feed PVC pipe through the loops in the tarp and use the wire around the pipe to pull the tarp tight and secure it. It can't move because the weight of the hay is holding it down.
Its quick, simple and cheap. We have never had one come lose so far.
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
Ground Protection Mats (A64194)
Ground Protection...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATERPILLAR...
2011 International DuraStar 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2011 International...
