John Deere 755 won't start!
/ John Deere 755 won't start! #1
BLC755
blc4570@yahoo.com
755 had been getting harder an harder to start temp no difference ! Crank an crank whit gray smoke unburned fuel new glow plugs still no start new injector lines and injectors bled all the way to injectors now not smoking!!! Somebody on here said glow plug relay module just got a new one today still no start !! About 1000 hours on engine getting fuel up to injectors !!!! Still cheaper than taking to dealer had this tractor 20 years with no problem till now!!! Anybody have any ideas!!!!
Hey thanks for reply you're the only one that's answered! Right now don't have air cleaner even on it still won't start ! Have it in shop! Had it off to bleed injector lines!!! It about has me ready to pull what hair I have left out!!! Bob
/ John Deere 755 won't start! #4
Make sure your fuel system is clean. The tanks on these have no drain and they will collect alot of dirt and water at the bottom of it. I had to remove mine as it had dirt and water in it. Is the tractor smoking at all when you crank it over? If its smoking, your getting fuel so its likely a glow plug issue.
/ John Deere 755 won't start! #5
You saying its not "smoking" says it is not getting fuel. Bleed it at the injectors and ge it smoking again. Ed
Thanks for your replies!!! I have bled lines all the way to injectors till bubbles stopped ! Fuel pump is shooting out diesel 4 or5 inches when I bled at filter and injection pump!!! No smoke!!!! I'm baffled ???? Bob
Thanks 4310 & Ed I bled & bled lines still no smoke no start! Would it still smoke with low compression ! I'm thinking it. Needs new rings or possibly more! The Bob
/ John Deere 755 won't start! #8
You need four things to start a diesel: fuel. air, compression and a good starter motor/battery. In cold weather there is a fifth requirement, a starting aid ( glow plugs,Thermostart, block heater).
Just because you see fuel coming from the injectors doesn't mean that you have adequate flow to continue starting and operating. If the fuel delivery is restricted , inadequate fuel flow will not allow the engine to start. The tank strainer can be clocked, fuel lines might be pinched or otherwise damaged, the fuel filter may be partially clogged, filter maybe frozen due to water in fuel, summer fuel maybe waxy due to low ambient temperatures. lift pump may be damaged (if you have one), the air filter may be clogged, fuel cutoff lever not opening etc, etc. The last thing to suspected the injector pump itself, but if everything checks out (in cold weather your starting aids are working, your batter & starter are strong) and you have adequate compression, the pump can't be ruled out. They are hydromechanical devices and they do break.
Thanks Jerry !!! I'll keep plugging away at it,!!!!! Bob
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2013 Chevrolet Tahoe SUV (A64557)
2013 Chevrolet...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
