Ford 3910 Front Axle Swap
   / Ford 3910 Front Axle Swap #1
jacain
Richmond (Chesterfield), VA
Ford 2600 Ford 3910
Was wonder if one of the guys who has wrenched extensively on these older 10 series Fords knows whether the 4610 (2wd) axle will swap into a 3910. I'm looking at a 3910 right now and being aware that it isn't really stout enough for loader work got me thinking. Thanks in advance for any info!
   / Ford 3910 Front Axle Swap #3
This looks like the whole setup. Doesn't seem like too much money in order to run a loader (with heavier loads) on a 3910. Might be able to find cheaper if patient.
Ford 4 Su Tractor Front Axle | eBay
That is a start. Add the correct steering box, grille shell, drag link, power steering lines and you are good to go.
FWIW the eBay stuff is from an AP model, not an SU. The OP already has an SU style front axle.
Thank you so much for the info! I was thinking it was miss posted as I was under the impression the su was the light duty version (as you confirmed). Now I just need to get the tractor and then keep an eye out for the front end parts.
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
FUEL TANK (A50854)
FUEL TANK (A50854)
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
