Ford 1700/1710 slow hydraulics
   / Ford 1700/1710 slow hydraulics #1
Squidbait
Abingdon, Virginia
2018 JD 1025R
Greetings gentlemen,
My pastor bought a used Ford 1700 or 1710 tractor (I'm not sure which model exactly) about three years ago. This past summer he started having issues with his 3 point hitch: it would raise very, very slowly and in a jerky or incremental fashion. I don't really have much more information than this I'm afraid, but would any you gentleman have some idea of what may be causing this behavior from his 3 point hitch/hydraulics? He basically uses the tractor to mow a couple of acres of grass with a finishing mower and to plow/till his garden. I have not seen the tractor operate in person, so I'm going only by what he has told me. Thanks for any info you gentlemen may be able to provide. :)
   / Ford 1700/1710 slow hydraulics #2
Greetings gentlemen, My pastor bought a used Ford 1700 or 1710 tractor (I'm not sure which model exactly) about three years ago. This past summer he started having issues with his 3 point hitch: it would raise very, very slowly and in a jerky or incremental fashion. I don't really have much more information than this I'm afraid, but would any you gentleman have some idea of what may be causing this behavior from his 3 point hitch/hydraulics? He basically uses the tractor to mow a couple of acres of grass with a finishing mower and to plow/till his garden. I have not seen the tractor operate in person, so I'm going only by what he has told me. Thanks for any info you gentlemen may be able to provide. :)
The screen for the hydrolic fluid is clogged. First you have to drain the hydrolic fluid from the rear axle. There is a bolt on the bottom. Be prepared to catch about 5 gallons of fluid. There is around a 1 inch pipe going from the engine area to the rear axle on the right side ( or passenger side) I believe the pipe is attached by banjo fittings. On the rear axle banjo fitting there is a cover with three or four bolts. take those out. That cover has the screen attached to it. Take it and clean it off using compressed air and I used an old tooth brush. Good luck. Do a search on this site it is a common problem.
Thanks for the info Btown. I will mention that to my pastor. Thanks. :)
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
2021 Fleco DX140 24in Digging Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2024 FORD F250 SUPER DUTY BED (A57880)
2024 FORD F250...
