Well Priming
/ Well Priming #61
I wouldn't be surprised but they outlawed them in Michigan in the 60's for new construction. I'm sure there are still quite a few left. And I'm sure some are bootlegged in.
If you mean the jet pump, it's controls are the same as a submersible. Pump, pressure switch and storage tank. There are constant pressure pumps out there now too, but they still need a tank and a pressure transducer.
By pump do you mean another pump besides the jet pump in the well?
/ Well Priming #62
I'm not sure what the questions is. The jet pump would be above ground. Submersible would be in the well. Putting a booster pump on along with the original pump wouldn't help at all, so there would only be one pump.
/ Well Priming #63
Jet pumps build pressure up to the residential use level...maybe higher, I don't know about that. Back in the day they were about the only thing available for deep wells - inefficient but they worked.
Harry K
/ Well Priming #64
We live in Florida so freeze is not a problem. We have a submersible pump that has 4 wires going down to the pump with the control box mounted on a pole next to the pump. The well casing sticks above ground so no need for a pitiless. The pressure tank is next to the well as is a manifold that allows us to turn on/off individual pipe runs.
It is much less expensive to run the needed size power wire to the controller at the pump then it would be to run that much pump 4-wire feed wire.
It is also easier to feed the distribution manifold.
Therefore, for us, much more practical to have the controls at the well.
/ Well Priming #66
They outlawed well pits in Michigan years ago. I would rather lift the lid and go down in a well pit than have to dig the well up and work over a hole to repair on the well. That's when Pitless Adapters became popular and put an end to all that digging. Many people had well pits attached to their basement, but the hole in the wall was much bigger than the OP's. They were toastie in the winter too.
confined space with the possibility a gas displacing oxygen. Same as the garage pit.
/ Well Priming #67
Looks like a very good, well thought out system. Everything out in the oopen for easy access. I for sure would do it the same way if it weren't for freeze protection up here.
Harry K
/ Well Priming #68
The well pits I see are usually around 4x4 around 4-5 feet deep. I don't consider that a confined space. Not sure if OSHA would consider it not intended for continuous occupcy, but I don't have hole monitor when I go in.
/ Well Priming #69
It would qualify. Pretty sure anyway. Haven't look at any spec sheets for many a year now.
/ Well Priming #70
just tap in another pressure tank to the system with a 1 way check valve and a manual on/ off valve to bypass the 1 way valve when the time comes ... keep the new valve closed and let the water fill the new tank thru the 1 way valve ....
part 2 ... install another on/ off valve to the bleed port and have it inside the house ...
result ... when you run out of water ( air lock ) ... simply open the new valve at the new tank full of pressurized water ... it will try to fill the well pipes ... then open the new bleeder valve to let the air out... the system will fill with water .... when full , turn the well pump back on and close the bleeder valve , then close the manual valve to the new pressure tank ...
/ Well Priming
Good idea. The reason we don't use a check valves is because of winterization of the plumbing. Up until this winter, nobody has spent a winter at this house for 20 years and so everything went into deep freeze including the top few feet of the well itself.
/ Well Priming #72
Bleeding my system takes a long time. I usually discover the air when the shower stops.
/ Well Priming
After 30 years of opening up, we've found every possible low point in the pipes, slopped the copper and added drain valves.
It all adds to the "charm" of the basement ceiling.
/ Well Priming #74
I am not talking about the pipes in the house. I mean in the pump and pressure tank. If the pump gets to much air, it quites sucking up water, water gets hot, and you lose water pressure in the middle of the shower.
Not sure why it takes so long, But I have spent lots of time bleeding off air at the pump. This is with a shallow well pump. Not sure how the other styles are. But pump keeps running never getting up to pressure, water in pump gets hot. Which is bad. Pump is cooled by water.
This happens if the water level drops in the well too. Could happen if the pipes going down had a hole above the water table.
/ Well Priming #75
I don't know how this would work with your well but around here I usually prime water pumps with a wet/dry vacuum. It just eliminates a lot of headaches.
I would take a sledge hammer and knock a few more bricks out of that hole. It doesn't need to be that small.
/ Well Priming #76
also the reason for the manual on/off valves to drain the system if needed ...
/ Well Priming #77
Keep in mind though that the water in that tank has been stagnant for however long. Not something you want contaminating the system. My interlock with the community well is 1/4 mile long, same problem and both users understand that, if used, run a sprinkler connected to the nearest standpipe for a good half hour.
We had to bleed all the fire sprinklers in the jail for maintenance. Stuff coming out was black and stank
Harry K
Harry K
/ Well Priming #78
Sprinklers stay sprinklers stay stagnant longer then most water systems.
/ Well Priming #79
And that water, if stagnant, does not feed back into the system, if it did it wouldn't be stagnant.
Harry K
/ Well Priming #80
I was on my smart phone and didn't finish my thougts. I was at my camp, where water stays in the pressure tank when I am not there. It comes out rusty when it sits, but so far has not killed me.
So 2nd homes or camps may go weeks or months, where a sprinkler I suspect goes longer.
