New House Build in the Country!!!
   / New House Build in the Country!!! #351
Construction Details - CertainTeed
This is a link that shows several ways to properly install flashing to a wall. I do not see this in your pictures. You might also google "roof to wall flashing" and click on the images link. There are a lot of pictures showing how it should be done.
   / New House Build in the Country!!! #352
I can certainly agree with your numbers. There are many reasons that closed cell is the best. I have lived in a house with a quiet HVAC system, and I miss it, but I am used to what we have now.
My question is more aimed at those of us who live in the deep south with months of 100F temps some years, as opposed to having to fight off the winter chill for many months. So with having to run the AC 6-9 months of the year, I was just wondering if the solar panels and the radiant barrier shade they provide would be better down here.
Kyle I just don't see the pay back when you run the numbers without additional subsidies on top of the federal tax credit. Im not against solar. I have 50kw system on our building. Our utility had a $1.50 per watt rebate at the time. Without it the numbers didn't work.
In fact I just ran numbers for a friend last week who was looking at an 18kw system for his home. Grid tied, professional install. Only subsidies available are the fed tax credit. Payback was about 22 years. If you have additional subsidies available from state or utilities it can be a very good investment.
   / New House Build in the Country!!! #353
It looks to me like they used black step flashing. To paraphrase Aaron Rodgers, r-e-l-a-x ;)
   / New House Build in the Country!!! #354
I've always found that relaxing wears me out. So, no thank you.
And did you look at my link that shows numerous examples of how it should be done?
I realize that I'm pointing out negative things in this build and a lot of you prefer to be cheerleaders, which I'm sure is very nice for the guy having his house built. But do you honestly want your house framed to old standards, things that are not done anymore? When somebody says that's how we always do it, I cringe. Continuing to do something the same way when better materials and techniques are out there goes beyond my comprehension. Supporting it is worse the putting your head in the sand.
Overall I give this framing crew a C grade. They seem to be fast and efficient. They have done this A LOT. No denying it. But my guess is that they learned their trade doing track houses and not custom homes. They are paid by how fast they get it done, not how well it could be done.
I have no doubt that the house will be nice when it's done and if any issues show up, they will be minor for the next ten years or even 20 years. The issues I'm seeing are what I repair in older homes. Things that take decades to happen. This is why those practices are not used any more. Nothing is 100%, so saying that's how my house is, or that's how they always did it might be fine for a few houses. Why gamble? Some people who smoke never get cancer. Is that a reason to keep smoking?
I personally post stuff on here so somebody will tell me what I'm doing wrong, or to tell me that there are better ways to do it. I'm currently redoing the siding on my house because I chose a Hardie product that I do not like anymore, and that has since changed how it should be installed. I still like Hardie, but I will never use their 4x8 sheets for siding ever again. I ignored the advice I received not to use it, and now I'm paying for that stubbornness.
I appreciate everyones input equally the good, the bad, and the ugly. To be fair - we are basically paying slightly over tract home pricing for a house that we were able to customize and build the way we wanted. We are happy with how things are progressing. Did we get the absolute best materials???? It's probably safe to say that the answer is no. On the other hand, if we had demanded nothing but the best, we would not have been able to afford the house we wanted. Is there a trade off - sure there is.....
   / New House Build in the Country!!! #356
Did you look at the pictures? View attachment 460470
I did see the properly installed step flashing going up the sidewall. I'm not sure what your link on built up roofing membranes has to do with it though? They are obviously not finished but I'd be willing to bet they plan to flash under the window before they are done, heck if they want to get fancy they might even build a sill pan out of ice and water shield to tie all together.
   / New House Build in the Country!!! #357
How would you go about installing the lower flashing AFTER already installing the side flashing?
   / New House Build in the Country!!! #358
One cheap thing you can now regarding air sealing is to make sure every hole and penetration through the building envelope is sealed properly. Your builder may or may not take this seriously. Cheap to do now almost impossible to do later.
Get some cans of spray foam and caulking and seal around every hole that is drilled before they insulate. Pay special attention to all the holes drilled into the attic area. Plumbers and electricians leave lots of air leaks when they do their rough in.
Check with your builder before doing anything thoug; your inspector might want you to use fire rated foam and caulking in certain areas.
What kind of caulk should I use?
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
John Deere HPX615E Gator 4x4 Utility Cart (A55787)
John Deere HPX615E...
UNUSED LANDHONOR LHR-BLC9021 TOOL STOOL (A54757)
UNUSED LANDHONOR...
MISC CABINET PARTS (A54756)
MISC CABINET PARTS...
2005 Woodchuck Chipper (NOT RUNNING) (A50775)
2005 Woodchuck...
