TZ22 Steering wheel removal
/ TZ22 Steering wheel removal #1
MattRay
Frankfort, KY
TZ22DA
I have a New Holland TZ 22 and it will not start. Glow plug light will not come on. Dealership said they believe it is the starter switch. I need to remove the steering wheel to remove panel to get to switch. I have removed Steering wheel nut, but I can not get the steering wheel to move. Any ideas?
/ TZ22 Steering wheel removal #2
Seems I was into one of those late last summer. Same type issue (key switch)and same problem with the steering wheel. I use a small bearing separator clamped under the wheel hub and a two bolt puller bar and screw. I've used this setup on many a steering wheel, and MOST come off without damage.
Thanks for the reply. I got it off with a bunch of PB blaster, knees under wheel, and light taps with hammer on spindle. Now to get the old switch out of dash
2025 66in Swict Bucket Skid Steer Attachment (A64553)
2025 66in Swict...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
LOT OF YETTER SHARK TOOTH TRASH WHEEL UNIT MOUNTED (A64278)
LOT OF YETTER...
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
