@$#&%*! battery terminal on 5035
/ @$#&%*! battery terminal on 5035 #1
Ram4x4
Nickleville, Pa
Mahindra 5035HST
So after three years the battery on my 5035 has died. No problem, I'll go replace it...or so I thought. I can't get the freakin negative terminal off the battery because the nut is some weird size. 8mm is too small, 9mm is too big. 5/16 is too small and 11/32 is too big! The nut is also recessed a bit and there is no way to get an adjustable wrench in there to loosen it.
Anyone else run into this? Is there some "special" size socket for this thing? 10mm fits the positive side no problem, it's just the negative terminal that's an issue.
(and the wife wonders when I grumble when I have to work on cars and machinery anymore).
Frustrated!
/ @$#&%*! battery terminal on 5035 #2
I've had a similar problem with battery nuts. My tool for the job is a pair of long nose vice grips, but you may not have access. Have you tried a multi-point box end?
/ @$#&%*! battery terminal on 5035 #3
Since the battery is no good, can you get under the clamp with a hacksaw and cut the post off? That would give you more room to attack the bolt, which probably started out as a standard size but ablated due to corrosion.
Alternately, you could disconnect the cable at the frame and take it out with the battery, if there aren't a lot of securing ties and such hindering that.
/ @$#&%*! battery terminal on 5035 #4
Word of the day on TBN, ablated. :) You don't have a chance to use that word everyday.
And I suspect you are correct, that thing is probably 9.2mm at this point.
No, there is no ablation that I can tell. If corrosion had done so I think the nut would have a weird shape, such as one flat being longer than the others, or an obviously "cruddy appearance" (I've seen nuts where rust has corroded them down like what you mentions). It's clean and pretty symmetrical.
9mm 6-point socket is too big, 8mm is too small. I also tried a 5/16 and an 11/32, 5/16 too small, 11/32 too big.
I will see if I can just cut off the post...ugh, what a PIA.
/ @$#&%*! battery terminal on 5035 #6
Can you use the closest next larger size of the 6 pt sockets and use a small piece of sheet metal or similar to shim the size? Bend it to fit the on two of the socket flats.
I don't have any sheet metal around that thin. I'm just going to saw the post off and be done with it. Once I get it off I'll modify the clamp so I can put another bolt through it with a "normal" sized nut that'll be easier to get to next time! Modifying the positive side too. Although I can get the 10mm on it, it's a little recessed and a little fiddly.
/ @$#&%*! battery terminal on 5035 #8
8.5, believe the 3 dollar cheap harbor freight set has it
/ @$#&%*! battery terminal on 5035 #9
Not even some heavy duty aluminum foil from the kitchen cupboard? :)
Fold the foil into some layers and tap the socket onto the nut if it's a bit tight with the foil filler. All you're needing to do is fill up some loose space in the socket.
/ @$#&%*! battery terminal on 5035 #10
At least it isn't a tin foil like thing that Toyota puts on its batteries. That seems to be the main downfall of Toyotas.
On them, you cut the end off the cable and replace the end or replace the whole cable.
Ralph
/ @$#&%*! battery terminal on 5035 #11
Replace the entire clamps and be done with it. I have done this with a good many of my family's vehicles and we never looked back. Some of the new battery clamps are nothing but cheese and I usually dump them on the first battery replacement.
/ @$#&%*! battery terminal on 5035 #12
^What he said.^
I'd hack saw the facotry lugs off and install something like these. 76806_3.jpg
Then crimp and solder some proper terminal lugs to the cables like these.
Slip some heat shrink over the joints then button it up.
/ @$#&%*! battery terminal on 5035 #13
Ralph
Agreed - those stamped terminals are pretty turdy. I'm sure they're cheap to make though. The worst is vehicles that have one of those with some kind of integrated fuse doo-dad on the positive terminal. Had to rig this up on my Frontier when its clamping mechanism self-desctructed. Flattened out part of the stamped terminal so I could attach it to a real cast terminal. :D
/ @$#&%*! battery terminal on 5035 #14
Most battery service kits have a small pair of Channel lock pliers in the kit for those stubborn nuts. ATEC & pcs Battery service kit , available at Acklands Grainger affiliates!
Cheers!
/ @$#&%*! battery terminal on 5035 #15
I'm thinking we can probably blame the EU for the battery terminal fiasco. Their RoHS requirements made mfg'rs take ALL the lead out of solder in electronics, etc and I am guessing that vehicle mfg'rs either chose or were forced to do the same with battery terminals. I knew a guy who drove a Triumph Spitfire back in the day - These new "clamps" kinda remind me of that car: I had the impression that it was so flimsy that a large beetle could have dented the hood.
But, know what? They're putting those no-lead terminals on batteries that are chock-full of lead! You can take the lead out of the clamp but taking it out of the battery ain't as easy as saying R-o-H-S.
Oh, as far as an 8.5mm socket - Come on, give me a break!! I see that they are actually made and sold (even 9.25mm sockets!) but, really? (http://http://www.nationaltoolwarehouse.com/14-Dr-SAE-and-Metric-STD-Turbo-Socket-Set-16-Pc-P39294.aspx)
2018 F550 Bucket Truck (A63118)
2018 F550 Bucket...
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
