Looking for some options on mounting a 2" receiver.
   / Looking for some options on mounting a 2" receiver. #11
I completely understand, take a bit and look around on here and you can fins several posts on different ways people have mounted a tube to the buckets, Some look almost factory.
   / Looking for some options on mounting a 2" receiver. #12
Here's what I did if you decide to do a bucket mount. I rarely if ever never even have to remove the ball mount. It's pretty much always there when I need it and I can change out quickly.
   / Looking for some options on mounting a 2" receiver. #13
I'd just mount the receiver on the top of the bucket like this.
Two 5/8" or 3/4" bolts welded to the top of the FEL bucket and mating brackets welded to the receiver.
Good luck
   / Looking for some options on mounting a 2" receiver. #14
I would reinforce the top of bucket with c-channel prior to welding the receiver hitch.
Eliminate chance of top of bucket bending
   / Looking for some options on mounting a 2" receiver. #16
If the top of the bucket is too high, you can get a clamp-on hitch that attaches to the lip. For example, one like this.
   / Looking for some options on mounting a 2" receiver. #17
That is precisely what I use
I also have chain hook on top of my bucket and use it for the safety chains just to be sure trailer can't get away from me
I added a cutting edge to bottom of my bucket and it adds a lip the clamp on can't get past
I like clamp in as it can be removed when not needed
I don't move my trailers around enough to warrant permanent fixture attached
Cutting edge eliminates chance of bucket lip bending
Joel
   / Looking for some options on mounting a 2" receiver. #18
I followed conventional wisdom and built a receiver into the bucket on my baby GT. I found it hard to see around the hood and bucket to get aligned to a coupler. And then I had to be careful of the bucket getting hung up on the tongue jacks. I saw a picture of the offset ball hitch for the QD, made one up, and it works really well. I need to have a care about the offset. Jay
I have seen the clamp on hitches and gave them a thought. I did wonder how easy it would be to pull it off the bucket, but that would give me an excuse to get a cutting edge! I am going to take a look at Jlwoodworks thred.
   / Looking for some options on mounting a 2" receiver. #20
2017 CATERPILLAR 259D SKID STEER (A52707)
2017 CATERPILLAR...
2012 Deere 333D (A53317)
2012 Deere 333D...
Mailbox (A55853)
Mailbox (A55853)
2022 Chevrolet Tahoe FL SUV (A55853)
2022 Chevrolet...
UNUSED FUTURE D39 39" HYD TRENCHER (A57193)
UNUSED FUTURE D39...
Estate Equipment Auction 9/27/2025
Estate Equipment...
