What have you done to your Branson today?
/ What have you done to your Branson today? #1
Zork
Virginia
'04 Branson 3520, '51 Fergy, '96 MTD 18/46, '02 Craftsman GT5000/48
I hope that this thread will continue as others perform maintenance or adjustments on their tractor. Century included.
My tractor seemed to be struggling with HP lately. The tractor did not roll on a slight incline as it did in the past. It turns out that the brakes were sticking.
I pulled the rear wheels and the levers to the brake assembly. There was rust between the levers and the brake housing assembly. I pulled the levers, cleaned and lubricated the area, moved back and forth several times, and reassembled. I also adjusted the linkage out because there wasn't much free play. Anyway, it is disengaging correctly and the brakes aren't sticking.
/ What have you done to your Branson today? #2
The more the better.
Tonight I pulled the black grill insert and straightened as much as possible. Darn log...
/ What have you done to your Branson today? #3
I was working on a lawn mower in the shop today and just looked at them as I passed back and forth to the tool box. Was going to kiss and hug on them but thought that was just stupid...........grin.
/ What have you done to your Branson today? #4
We would understand...
/ What have you done to your Branson today? #5
Moved a few around the lot today. That's about it. Although recently installed a front mount 76" hydraulic snow blower on a 4520C. Anyone interested in pictures on this? I have some..
/ What have you done to your Branson today? #6
1) Moved rear wheels to outer adjustment and gained 4" overall width. Owners manual call for 250 ft lbs on outer ring bolts and 280 on inners. The two studs on the inners didn't seem to like the 280 ft lbs (felt like on verge on stripping out) so I will probably go to 250ft lbs on all of them next time.
2) Felt like loader was hitting relief to soon, so as an experiment I adjusted the loader valve setting an 1/8 of a turn clockwise and tested it out. Made a big difference in lift capacity when tested on downed tree. Set back to factory setting until I get a gauge to see where I am really at.
/ What have you done to your Branson today? #7
Not today, but this week put a small lightbar on the ROPS so I can see at night.
I greased most of my fittings late yesterday. Since the grease seams harder in others (unloaded) I think I will need to pull some of them and clean or rotate them.
I added this 7.5 foot meyers a few winters ago (?) but I had problems controlling it. It worked flawlessly this winter after changing the mounting system. I removed the upper mount and chain connection and went with a rigid link. I had minimal gravel/slate loss.
I am interested in the pictures.
Changed the engine oil and filter, cleaned the air filer and radiator grill. I investigated my rear main oil seal leak and I think I have that fixed. I checked the bellows on my CDR-like valve, and checked the breather hose for obstructions such as a dirt dobber nest- all good. For some time now the dipstick has been real loose and sloppy in the tube. When newer, the dipstick was snug and provided an airtight seal. I installed two 006mm o-rings on the rubber portion of the dipstick; one o-ring in each groove and now it is good and snug. After running the engine for half an hour my rear main seal leak has stopped (let me know if anyone needs photos). I am so happy because I was not looking forward to splitting the tractor to access that seal.
/ What have you done to your Branson today? #12
I bought my Branson today. It'll be here on Tuesday. Longest weekend of my life, starting tomorrow!
Congratulations! and, welcome to TBN.
I have no regrets with this purchase, and I hope you have the same.
/ What have you done to your Branson today? #14
Which model did you get?
I got 15 hours on mine and so far I am pleased.
I used mine to bring water to the west acres until the rains come.
/ What have you done to your Branson today? #16
I decided to tackle the big debris pile, got sloppy and rolled a stump onto the BH hydraulics...
I feel your pain.
/ What have you done to your Branson today? #18
Put on repaired ram, was cheaper than I thought, $200 shop min...
/ What have you done to your Branson today? #19
I got the 4520R with a hoe. Very pleased thus far.
Used mine to bring barrels of water to the outer property line. 357 hours on mine.
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
Komatsu Excavator (A60352)
Komatsu Excavator...
