Bobcat 331 Miniex. arm falling or dropping after full retraction, help please
   / Bobcat 331 Miniex. arm falling or dropping after full retraction, help please
Something seems to be stuck open. It is free falling down. Have you talked to a bobcat dealer or mechanic?
no, i haven't talk to a mechanic yet, i'm trying to find the problem after getting some info here with you guys before i take it there. could a house leak cause this issue?
   / Bobcat 331 Miniex. arm falling or dropping after full retraction, help please #13
I am wondering if the cylinder rod o rings have failed. Have you tried lifting a load? Seems it can lift itself but not hold. That indicates failed o rings inside the cylinder.
   / Bobcat 331 Miniex. arm falling or dropping after full retraction, help please #14
Dave I don't think so. The fact that it falls faster after cylinder has fully retracted suggests the problem lies elsewhere. Of course it is possible that the cylinder packing is leaking as well, in that case there are two problems. I would focus on a valve problem before considering the cylinder packing to be worn out. Stoneandbrick I would ask on the forum too (before going to a professional) because you can better assess the diagnosis (or the cost :cool:). It may cost less if you can find the problem yourself. But if that machine needs to make money now, you may be losing (now).
Try posting your video in the Hydraulics section; maybe you can get the attn of J_J. You might mention the number of hours on the machine.
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
UNUSED JCT SKID STEER QUICK ATTACH PLATE COMPACTOR (A51244)
UNUSED JCT SKID...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
(2) ALEMITE GREASE HOSE / REEL & NOZZLE W/ GAUGE (A51244)
(2) ALEMITE GREASE...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
