Leaking arbor press telescoping cyl.
/ Leaking arbor press telescoping cyl. #1
City Farmer
Chesterfield, Mi
Ford 3000, 4400 & 4500TLB Case 830 Case 350 dozer
Hi all. I'm at the point where I have to get my arbor press working again. The cylinder is leaking from the top seal. It pumps up a little bit, then bleeds out all over. I've never taken apart a telescopic cylinder before. Can anyone tell me what I'm in for and what the problem could be. If possible, I'd rather try fixing it myself before sending it off. I'll get some pictures later today or tomorrow.
Thanks.
/ Leaking arbor press telescoping cyl. #2
The top seal is pretty straight forward. I don't think there are any internal seals.
Seriously, that's all there is to it! Lol
I completly over thought this one.
Thanks.
/ Leaking arbor press telescoping cyl. #4
Is your press a hyd cyl or a hyd jack?
/ Leaking arbor press telescoping cyl. #5
Check out YouTube there's a video for everything I've been watching them preparing to rebuild my stabilizer cylinder
I'm not following you? It's an I-beam hyd. arbor press. It's pretty heavy duty, I "think" it's a 30ton unit.
/ Leaking arbor press telescoping cyl. #7
Man I don't know where my mind was at when I asked that, sorry.
The press has a 5" diameter cyl. I tried looking up the model # but I can't find much info on it. I'll shoot them an email and see if they still support it.
/ Leaking arbor press telescoping cyl. #10
Nice looking rig. I think you will find it is pretty simple rebuild. Cleanliness will be very important to protect the seal and cylinder after assembly.
Worst case you can take the jack to a hydraulic repair shop for rebuild.
The hyd. shop may be able to provide you with the info and seals for it.
I'm going to try rebuilding/fixing it myself. The last time I took a cyl to the shop I left $350 lighter in the pocket. It's a 50ton press that is no longer serviced. He said I have 2 options. Take it to a hydraulic shop and see if they can order the metric seal for it. Or swap the cylinder out for $589 + shipping.
/ Leaking arbor press telescoping cyl. #12
I actually have some seals for those Carolina Tool press cylinders
If you get it apart, please get the metric dimensions (od x id x height) I'll look in my stock inventory
