Heat treated welds
/ Heat treated welds #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
Why would that be advantageous on an anhydrous tank? What does post-heating a weld do?
I ask because the Iowa legislature is considering a bill to require it on all anhydrous tanks made in the future.
/ Heat treated welds #2
Heat treating allows all the molecules to realign after welding which removes stress so it makes the steel stronger. In some steels heat treating makes the steel more resistant to corrosion also. This may not be just for the welds either, it could mean a furnace heat treatment for the whole vessel which is going to add a lot of cost to the vessels in the future if that is the case.
Thanks Gary, I've had enough high school science to understand that. These tanks are 1000 gallons so I am guessing it would be spot treated. Would there be an obvious sign of heat treating or do you think it be simply a certificate of some sort of proof of heat treatment?
/ Heat treated welds #4
Follow the money, I would assume that some senator's getting a kickback from a manufacturing facility that already is capable of such a procedure. Thus tossing it into the amendment...
/ Heat treated welds #5
Exactly what I was thinking.
/ Heat treated welds #6
Usually only the really critical vessels get stress relieved and they do the whole vessel in large heat treating furnaces. They heat the vessel up around 1600 deg's if I recall and hold it at that temperature for a specified length of time and then slow cool it. Sometimes companies goof and after heat treating a vessel weld ladder clips or name plates on which negates the stress relieving. With have shop in Edmonton, Dacro Industries that has the largest heat treating furnace in N America. I imagine it's not cheap to heat it up. There's some pics in the link below. Some thick vessels can take more than 24 hours to cool off.
Dacro - Heat Treating Equipment
/ Heat treated welds #7
That or in response to a recent incident.
Was there a recent accident involving weld failure on one of them tanks in Iowa?
I don't think so, I think I probably would of read or heard about any accident of substance.
I am guessing the reason for the change is because they are probably made to the same specs. as a propane tank. Compared to a propane tank, anhydrous tanks get the "snot" beat out of them.
/ Heat treated welds #9
I suppose this could also be possible. I don't know a whole lot about them but I assume they are not under high pressure, perhaps mounting tabs for the road chassis' are being ripped off during transport and thus causing spills or something...
/ Heat treated welds #12
There are companies through out the US that specialize in weld stress relieving and come right to the site.
CROP CARE PLASTIC PLOW / LIFTER (A63291)
CROP CARE PLASTIC...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
429888 (A61165)
429888 (A61165)
POLY TOTE W/ CAGE (A63291)
POLY TOTE W/ CAGE...
1992 John Deere 210C 58HP Loader Utility Tractor with Box Blade (A61572)
1992 John Deere...
