How can I straighten this?
/ How can I straighten this? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
In one of my more brilliant moves, I managed to bend a couple of studs as part of a caster assembly and figured the fine folks here is the weldiing forum might give a clue on how to straighten them. I don't have O/A only a little propane torch and I am having a heck of a time clamping the caster well enough to bend it. I tried putting some heat (not enough obviously) and threaded a coupler and some all thread rod for leverage to no avail. Here is a pic of what I am dealing with. 1/2 - 13 thread dia. Ideally, SA will chime in and say "come on over, I fix it!"
/ How can I straighten this? #3
Just my 2 cents.
I've had limited success by threading a nut on then clamp the nut in a vise and tap the bearing cap with a hammer. Or while the nut is still in the vise use a small crowbar in the gap between the wheel and bearing and pry it back
Sometimes it will straighten back up others it will break right off. If it straightens I can use it, if not go buy another.
/ How can I straighten this? #4
Take the caster wheel off then put the bolt back in. Slip a piece if tube in there between the caster body and bolt then use a piece of pipe over the bolt to pry it straight
Just my 2 cents.
I haven't been able to find the same ones yet online. They are locking swivel and rolling type for a roller feed table. I need them to be 1/2in dis stud style as well.
That sounds like it is worth a try. Thank you.
/ How can I straighten this? #9
Yea I was gonna say I'm 100% positive they can be sourced
/ How can I straighten this? #10
Take the wheel off. Cut broken stem off and or drill it out. Weld on new threaded stem using all thread or fully threaded bolt.
This IS a welding subforum. Mark. :). Good luck.
Terry
/ How can I straighten this? #11
Put a nut on the end of the threads, and clamp a pair of Vice-grips on it.
Heat the bent part with a real torch, and it will straighten like butter.
Don't you have a auto repair shop, or something near by, that has an acetylene torch? It will take about 10 seconds.
Most places do things like this for "goodwill". We used to, all the time.
Slip the guy a $5 bill when he is done, or offer to bring doughnuts in the AM.
Terry
Thanks Terry... yeah I did buy the all thread to do just that but thought I might try to bend it back first. Oh and I deserved that!
/ How can I straighten this? #13
Just my 2 cents.
Terry
Both are great ideas! :thumbsup:
Well I fixed it! I really didn't want to weld it because I wanted the stud and nut to seat against the insert in the bottom of the leg. A fillet weld would mean I wouldn't be able to fully seat the threaded stud down to the nut. Thank you aarolar... I did as you said, took the wheel off and used a long piece of pipe for leverage against the body and the bolt and screwed a coupler on the stud as far as it would thread and then screwed some all thread on to the coupler to give me leverage on that end. Put the coupler in the vise and presto... bent it with my bare hands and no heat! Roller table fixed and back in operation! Repair cost zero :cool2:
By the way I found the caster on line and it was running about $23... ouch.
/ How can I straighten this? #16
Have someone heat the stud while you add "several" nuts to it, when the stud is full of nuts, slowly straighten it.
2025 IRANCH IRLMB Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 IRANCH IRLMB...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
