Very weak bucket curl
/ Very weak bucket curl #1
ssrider
Member
East Selkirk, Manitoba
1963 massey 150, 1972 Dynahoe 190
I have a 1964 MF 150 with aftermarket Allied loader. Loader is run off the tractors internal hydraulic pump. I bought the tractor last year and it's always had a very weak bucket curl. The loader arms have plenty of lifting power and will lift the tractor no problem. The odd thing is the bucket will support any weight I put in it no problem if lifted with loader arms only. If I try to curl even a half bucket of dirt it won't, the bucket will just remain in the same position. I changed the control valve to a joystick style a few months after I bought it, so the valve cant be the problem. Any ideas on what the problem could be?
/ Very weak bucket curl #2
How many and how large are bucket rams?
What is the geometry like? Although unlikely the problem
Did you test pressure to rams?
Joel
/ Very weak bucket curl #3
Sounds like bucket seals are in need of replacing. If bucket seals are worn, fluid can bypass the piston seals and return to tank. More noticeable on lower flow (GPM) hydraulics. Do you notice a difference in "power" from idle vs WOT?
/ Very weak bucket curl #4
Extend the bucket fully, and then remove the rod end hose and then extend the cyl more and see if fluid is pushing past the piston seals.
Do the same with retract and remove the base end hose and see if the seals are leaking both ways.
You can also tee a hyd gauge in the work port and see if the cyl can build up relief pressure.
There's 2 bucket rams, I believe 2" diameter. I haven't checked pressure how would I do that?
If the cylinder seals are warn and leaking would the bucket still support weight without slowly dropping? I don't really notice a difference in curling power at wot, Just quicker cycle.
J.J. That's not a bad idea. I will probably try that.
One thing I forgot to mention is the bucket cylinders also feel "spongy". If I jump on the bucket it bounces slightly.
/ Very weak bucket curl #6
You were just told how to check pressure.
does your joystick control have a separate relief? do you know what it is set at?
Yes I know I was told how to check pressure. I replied to comments in the order I read them. Should have deleted that question after reading the answer in JJ post.
Yes the joystick has its own relief. I believe it came set at 2000 psi. I'm also pretty sure the relief valve on tractor trips and the joystick doesn't. Maybe the relief valve on tractor is the problem? I suppose the pressure test would answer this question
/ Very weak bucket curl #8
100% possible.
When trying to curl, the valve is pumpong fluid in the rod side port and opening the based end port to tank to allow fluid to return. If the seals are shot, some of the fluid you are pumping in the front can return to tank after leaking past the seals. Thats why I said it would be worse at a lower flow rate (slower RPM) vs a high RPM.
When just holding a load, there is no way for the fluid to return to tank. Even if the seals are shot. And for fluid to leak past the piston means drawing a vacuum and sucking in into the cylinder or out of the fluid for the bucket to drift.
/ Very weak bucket curl #9
you need to see what pressure the system is tripping at, then go from there. As LD1 mentioned, you could be bypassing on the curl cyld's. if they are parallel, only takes one to leak..
Thanks for the replies. I will check the trip pressure as mentioned. I could see it being a bad cylinder seal. They are cheap cylinders and look like they've had some abuse.
/ Very weak bucket curl #11
If everything else is working, and it's just the cylinders for the bucket curl, one or both of them are probably worn out. Usually it's the seal around the piston, but I've seen the actually cylinder worn down too. I wouldn't waste my time doing any tests, I'd just remove both cylinders and take them to a cylinder repair shop. Here, it's about $100 each to have a good sized cylinder rebuilt. I used to do them myself, but it takes a few hours, and the parts can run anywhere from $30 to $80. Most parts come in kits to handle a variety of cylinders, any you rarely use a quarter of them. The cylinder shop just buys the exact parts they need. They will also measure the cylinder to make sure it's not warn. If you need a new one, they will have the best price. If you don't know of a good shop, talk to the parts guys and mechanics at your dealership. In my area, they farm out all that work to the cylinder repair shop because he's faster and cheaper then what they can do it for.
/ Very weak bucket curl #12
Imho, the yes is needed to properly diagnose the issue. Its free, and is actually step one in removing them anyway.. Is remove a hose, then pressurize in opposite direction, answer will be forthcoming. If there is a leak, keep removing them, if not, keep looking.
That said, it DOES look like cyl seals from reading thus far.
2013 Ram C/V VAN (A61574)
2013 Ram C/V VAN...
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A61573)
2013 International...
2014 Land Rover LR2 AWD SUV (A61574)
2014 Land Rover...
KITCHEN AID REFRIGERATOR W/DRAWER FREEZERS (A64281)
KITCHEN AID...
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61572)
2020 Toro...
2017 Kia Rio Sedan (A61574)
2017 Kia Rio Sedan...
