An Air Filter for the 4500Y's Fuel Cap.
   / An Air Filter for the 4500Y's Fuel Cap. #11
Murphy, when you get a round tuit, check you first in line fuel filter. You may not have the same midges in your area.
prs
   / An Air Filter for the 4500Y's Fuel Cap. #12
prs
We don't get midges till summer.
John, Can you post a pic of the bottom of your cap as I can't seem to find the problem.
Here you go...
   / An Air Filter for the 4500Y's Fuel Cap. #15
I have the same cap. Which auto parts store will carry 14-2580?
Yes, you want to check the first on-line filter, nearest the fuel tank, mounted in the center tunnel, below the fuel shut-off valve. That's the one that traps pretty much whatever foreign matter gets into the tank. CarQuest sells a replacement if you need one... CarQuest No. 86032. The only difference relative to the Kubota OEM filter is that the Kubota's body is translucent plastic. CarQuest No. 86032 has a metal body.
CarQuest also sells an oil filter for the Kubota Diesel engine... CarQuest No. 85358.
I believe that Wix makes the CarQuest-branded filters.
We, too, don't get midges till summer around here. I suspect that the midges that drowned in my fuel tank got into the tank sometime last summer, or in the first part of the Autumn.
   / An Air Filter for the 4500Y's Fuel Cap. #18
Had ALL my filters changed last month after the hydraulic filter update. But I'll use the K&N trick today.
   / An Air Filter for the 4500Y's Fuel Cap. #19
Well I went to 3 stores Advance auto, auto zone and carquest. That # does not work at all. Carquest here does not carry K&N but will order it if the # was good. Please check your #.
   / An Air Filter for the 4500Y's Fuel Cap. #20
Murph!?!?!
I realize the bugs are not flying about up there in the snow, but its the ones from last summer/fall. See now that you have new filters. Another source for air filter material that can be cut to size are the open cell foam Shop Vac pre-filters.
But, hey; do take care with those darned snow snakes! Might need a flask of brandy handy just in case of a bite. ;-)
prs
Honda utv cart (A56859)
Honda utv cart...
2022 Ram 2500 (A55973)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
