Please clear this up for me
/ Please clear this up for me #1
07wingnut
Clearwater, BC, CA
BX23
I have a BX23 with FEL and BH and the manual states that the 3pth is inoperable when the BH is attached. Because the 3pth is sandwiched in between the tractor and the backhoe, it is physically inoperable, but as far as I can see, the hydraulics should work as if the BH was not there. No BH, there is a closed loop from connecting the hoses together, with a BH, there is still a closed loop thru the Open centre BH spool valve. So what has changed?
Also, if I take off the BH, and use the rear tractor hoses to connect a double open centre spool with no PB (the outlet hose is connected to the tank), can I use the QDs from the spool the run the BH if the spool valve is held open as is done when running a wood splitter?
Any input is appreciated
Thanks
Oops, I see the 3pth is the last in line in the hydraulic circuit. In that case putting an inline spool with PB and hooking the BH up to one of the spools should work.
Comments?
/ Please clear this up for me #2
My BX 25 lift arms work W/BH hooked up. Sometimes I forget to raise the arms first and can do after BH hookup. You are right on the PB circuit, BH on all down stream items work, the BH is first inn the circuit when hooked in the Hydraulics.
Ron
/ Please clear this up for me #3
My BX 25 lift arms work W/BH hooked up. Sometimes I forget to raise the arms first and can do after BH hookup. You are right on the PB circuit, BH on all down stream items work, the BH is first inn the circuit when hooked in the Hydraulics. Ron
Gee, I never even considered the three point hitch arms when I put my BH on in the spring. Are you supposed to raise them up?
2001 Freightliner MB55 Bus (A61573)
2001 Freightliner...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
2016 Ford Explorer (A61574)
2016 Ford Explorer...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
2013 Chevrolet Traverse SUV (A61574)
2013 Chevrolet...
