Ability to climb and descend steep grades.
   / Ability to climb and descend steep grades. #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
One of my projects on the ranch is to put in a firetrail/firebreak along the fenced property boundaries...
It's been let go over the years and access is an issue...
Over the last two years I have been using the Deere 350C to make my way... so far so good.
Some of the slopes must be 45 degrees... if not then close to that.
It sure would be easier and quicker to have a small ATV for checking and mending the fence line.
Never owned one and don't know anyone close with one.
How stable and how capable are these small ATV's?
I would imagine 4wd with 4wd brakes a must and excellent parking brakes because at some places there is nothing flat... either it is up or down... with the dozer I set the brake and use the blade for a brake...
   / Ability to climb and descend steep grades. #2
Many, many, many folks have been injured on ATVs. There is a definite technique to riding one on steep terrain. If you have no experience you will probably tip it over backwards during the learning curve. An experienced rider can go places you cannot imagine. And as an unexperienced observer you will never fully grasp how it's done. Only seat time will give you that knowledge. It's a hard learn.
Would that include the RTV like Kubota and Gators?
The only surefooted machine I am most comfortable with is a small Dozer... I will back up and if to steep it won't go and then I drive back the same path... the front blade and rear rippers make amazing brakes.
I'm most uneasy on side hills with the Kubota and Deere TLB... things that don't phase me in the least with the Dozer are different on a TLB.
   / Ability to climb and descend steep grades. #4
UTVs (RTV, Gator, Rhino, Ranger, etc) are much more stable than an ATV. Tip over backwards incidents are much less likely. Side slope roll overs are also less likely. Injury is only less likely if seat belts are used.
The comparison of UTVs and ATVs is minimal. They simply are not the same thing.
A 4x4 ATV will weigh around 600lbs. A 4x4 UTV will weigh around 1300lbs. The Kubota RTV is near the heaviest at 2000lbs.
Good point... I need to get my terminology correct... I have seen ranchers with Honda Ranchers which look like a 4 wheel motorcycle.
I'm thinking of a RTV like one of the newer Kubota's depending on finances...
Sure would be nice to be able to do a Demo at the property... imagine tires make a big difference too.
   / Ability to climb and descend steep grades. #6
I have a Kubota RTV 500 gas Utility Vehicle. It is very stable. I have the optional $250 Turf tires, which are really R4 Industrial tires. Money well spent for increased stability in your extreme scenario.
All Kubota Utility Vehicles have HST transmissions and differential locks. You know the value of HST engine braking.
The diesel Kubota Utility Vehicles are heavier, WIDER and require greater turning radius.
I also have an all terrain MUTS trailer ($1,849) with low pressure tires. It goes everywhere the RTV 500 goes, trailer full or empty. (Full trailer of dirt excepted.)
The cargo bed of my RTV500 stays loaded with tools: Chainsaw, Reciprocating Saw, 2-stoke gas, bar oil, loppers, manual pole saw,. fire shovel, etc., so I have the MUTS trailer connected most of the time. Buy a dumping trailer.
I have never owned or used a POLAR trailer but they appear to be great value.
(With the US$ very strong and the Canadian Loonie very weak, two axle MUTS trailers are cheaper now than when I purchased my single axle MUTS from Larry Edwards four or five years ago.)
LINKS (2): MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler - Welcome
https://www.google.com/?gws_rd=ssl#q=home+depot+polar+trailer
   / Ability to climb and descend steep grades. #7
I started with 2wd ATV and then 4wd ATV and then Rhino ATV and then Kubota RTV. Very little comparison between any of them.
If all you are after is basic transportation, ATV.
If you want a more comfortable ride with some utility ability, UTV.
If you want a miniature work truck, RTV.
It's all about your intent.
I still have a Rhino and RTV. The Rhino rides nicer and is more Sporty. The RTV is a workhorse.
I bought both used. Paid $7K for the Rhino with 25hrs. Paid $5500 for the RTV with 186hrs.
Good luck in your search. If you wanna come to missouri you are welcome to test drive my stuff. :)
So the no issues with the RTV500?
Don't know anyone with one... had a friend with a 400?
He liked it OK but his place was dead flat.
My neighbor in the Bay Area has a Gater he bought new... single cylinder gas... he uses it all the time... it only has two wheel brakes and when he came over to my place he nearly ended up in the creek... white knuckle ride for sure.
Mighty neighborly of you... definitely looking at the work side of things... it would be also nice to be able to take elderly out sometimes around the place... my soon to be 82 year old Mom was all over the ranch yesterday... her 65 year old friend had trouble walking to the barn...
   / Ability to climb and descend steep grades. #10
My RTV is an '08 900 diesel, hydraulic bed dump, hydraulic 4 wheel brakes. I added taller, aggressive mud tires. Get along fine with it. Slow at 25mph top speed. I never road it and only use it to work on the farm.
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56438)
LIKE NEW 2023...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
24in pin on tooth excavator bucket (A56438)
24in pin on tooth...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
CAT CB34 (A60462)
CAT CB34 (A60462)
