Hitch & Small Dump Trailer for BX
/ Hitch & Small Dump Trailer for BX #1
Samwise
Member
North San Juan
Kubota BX2370
Getting close to the second season with my BX 2370 and 50 hours I find I need all sorts of attachments and add-ons. I have the piranha tooth bar and belly armor already (wife's Christmas presents:)).
The bucket really is not that huge and to haul stuff around (firewood cut on the place is a prime example) I need a small trailer, probably single axle two wheel, that can preferably dump (by hand or mechanical means, does not need to be hydraulic). It should be no wider than my 54" MMM but a garden tractor trailer is just too small.
Would appreciate the forum's suggestions on that and a receiver hitch mount to go with it.
/ Hitch & Small Dump Trailer for BX #2
How about a hydraulic or PTO driven manure spreader. Just take the beater bar off and use the walking floor for unloading.
/ Hitch & Small Dump Trailer for BX #3
Can't help with the trailer, might check Northern or Gemplers. I just bought a receiver hitch from BxPanded, Redline Systems Inc. also has one.
/ Hitch & Small Dump Trailer for BX #4
MUTS is The Best but pricey: MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler - Welcome
OTHERS:
Polar --- Polar available from Home Depot web site.
https://www.kingkutter.com/store-product.aspx?id=3511
BHF MFG, INC. | YardBrute?compact ATV easy-dump trailers.
ATV Utility Dump Trailer - Workman Trailer by ABI
http://www.cienormand.com/anglais/trailer_farm1920.htm
http://weberlane.com/home-contractor/dump-trailers/estate-level/
Cursor down to 'Pat's Easy Mover': http://www.greenwellmfg.com
Easy Mover VIDEO: https://www.youtube.com/watch?v=nnLaV2w6sVs
If you want to take the trailer over rough, uneven ground you want a trailer where the load is carried low, between the wheels, like the MUTS, not high, above the wheels. See photo.
HITCH 26": http://www.agrisupply.com/handi-hitch-with-clevis-and-balls/p/61559/
http://www.redlandhill.com/Short_boom_pole.html
HITCH 20": http://www.redlandhill.com/Handi_Hitch.html
I use a 20" Handi Hitch on a BX2230. Very strong. When you remove the clevis shackle you have the hole for a pin hitch.
/ Hitch & Small Dump Trailer for BX #6
The best thing I've added to my BX is a front hitch. I bought a 4x6 dump/tilt trailer from craigs list for $400 and use it both around the house and also to pick up manure, mulch and gravel from the local ag supply.
This trailer is so well balanced that I can unhook it from my truck spin it around and hook it up to my BX front hitch, loaded. It's a convenience that I would suggest to look for. Mine is a store bought trailer built in '85, 12 ga steel body, removable rear gate, 14" tires, sides were made from old pallets.
I modified a HF trailer dump unloader (~$25 on sale) to fit the trailer width (use a hot knife) and now it's my 2nd favorite back saver next to the front hitch. The unloader make dumping mulch, soil,etc much easier. And pushing a trailer is much easier if you have trees around and need to dump a load in a specific spot as well.
/ Hitch & Small Dump Trailer for BX #7
I've got the HF 4' x 8' trailer, which I got on sale for around $230 a few years ago, and I put about the same amount into deck and sides and ramp. I use it for many things, hauling wood is one. But, I just recently saw one of these for sale, an assembled kit, new, for $150 on Craig's List, and almost bought it just for wood. The problem is small tires, which don't have much flotation on soft ground when you have a half ton of wood in the trailer... I was going to finish it like my other little trailer, but decided to keep looking for an off-road only trailer.
Ironton Utility Trailer Kit with 40in. x 48in. Bed — 1060-Lb. Capacity | Trailers| Northern Tool + Equipment
P1010170.JPG (trailer now has a 4' x 4' hinged steel mesh ramp for loading and some other goodies- as well as rusted paint- HF uses lousy paint.)
/ Hitch & Small Dump Trailer for BX #8
PeterK,,I like that wood shed build, I think I'll copy your set-up.:thumbsup:
/ Hitch & Small Dump Trailer for BX #10
It's an Adirondack style lean-to. Basically a shed with an overhang, all local Hemlock post and beam construction. Floor and back wall are spaced for air flow. Thanks!
/ Hitch & Small Dump Trailer for BX #11
This one I made for my BX2660 and it's just right. It's hyd dump.
/ Hitch & Small Dump Trailer for BX #12
Consider the trailer width and your clearances, especially in turns.
I'm gathering materials for a BX trailer. but it needs to be no wider that the tractor. I have several places with only 2-3 inches clearance on each side.
I have a 4x8 highway trailer that can go on only a few of my tractor trails, and a little garden tractor trailer too small to be of much use.
Bruce
Yes this is my situation exactly. I have a 4'x8' single axle trailer already. That is too big and the tires are for hard surfaces not my field trails.
Leejohn's above is about right - if he would just make another and sell it to me for $500!!! I could use some kind of hand crank with cable just like boat trailers for the dump to avoid the cost and complexity of hydraulics but the small size with bigger tires looks like a must have.
I'll have a look at the links everyone's posted and the referenced threads below.
thanks everyone and if there's any more ideas keep 'em coming.
/ Hitch & Small Dump Trailer for BX #15
Check out DR versa trailer. Comes in single and double axel versions pricey but they are robust.
/ Hitch & Small Dump Trailer for BX #16
King kutter xb dump trailer is about the best u can buy... I have had and repaired many others .11/2 ton cap with hand op hydro or can b hooked 2 remotes .Downside 2,700$:confused2:But well worth it I use mine all the time .:cool2::drink:
/ Hitch & Small Dump Trailer for BX #17
http://www.truckpaper.com/list/list.aspx?ETID=1&pcid=2001227073&dlr=1&bcatid=2]Jim's Farm Equipment[/url]
he is the guy who manufactures the King Kutter XB trailer and sells the equivalent for less.
There is also the ATV Wagon trailers which are reasonable on eBay. (ABI trailer is the same trailer also but the eBay deal is still best)
1600 Utility ATV Wagon - Power Dump Cart, dumping ATV Trailer- Power RAM strongest, best, ultimate atv farm trailer, atv ranch trailer
ATV Wagon 22 Cubic Foot Tandem Axle Steel Dump Trailer | eBay
John Deere 630 (A64119)
John Deere 630...
2015 GMC 1500 Sierra Crew Cab Pickup Truck (A61573)
2015 GMC 1500...
2016 FORD EXPLORER SUV (A59912)
2016 FORD EXPLORER...
2020 John Deere 6120M (A62180)
2020 John Deere...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
SHEPPARD 400 GAL FRONT MOUNT POLY TANK (A63291)
SHEPPARD 400 GAL...
