Damaged block installing block heater L5240
   / Damaged block installing block heater L5240 #281
Aaron are there piston cooling jets installed in your block?
That piston would be a cool ashtray.
Fred
Aaron are there piston cooling jets installed in your block? That piston would be a cool ashtray. Fred
Yeah, kind of like slotted disc brakes?
I got jabbed about once every 15 minutes last night by my dad and uncle. Even though I made some work for them, they are having fun at my expense.
I'm working on being the best darn bad example there is.
   / Damaged block installing block heater L5240 #283
He just turned 40!
I certainly meant my comment about the older guys in the shop as a positive. Those guys have probably seen it all. I immediately felt like I had known them for years..
Before I went, I envisioned it being some kind of speed shop where they work on hot rods.. Seeing all of the big diesels made my confidence go way up.
I think a good shop needs:
1 old guy who's done it all
1 middle age guy who does it
1 young guy who is watching and learning
   / Damaged block installing block heater L5240 #284
Piston cooling jets.
Fred
   / Damaged block installing block heater L5240 #285
Very true. I'll that all three need an overwhelming desire to do it correctly. :)
Well, we are at the half way point on the project today. The block is 100% stripped. This week it goes to the machine shop while I order parts. Probably two weeks before we'll get to work on it again.
Main bearings were iffy. We're replacing those as well. Crank surfaces look good though.
   / Damaged block installing block heater L5240 #287
The kidding stops after 10 years or so.
   / Damaged block installing block heater L5240 #288
The kidding will continue until there is another event that takes its place...
Here she is..
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
(3) 2000 LB FLIP UP TRAILER JACKS (A57192)
(3) 2000 LB FLIP...
70pc 12ft.x 3ft. Grey Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
Black Tip Steer Horn (A55853)
Black Tip Steer...
