RPMS drop moving forward?
/ RPMS drop moving forward? #1
HK45
Gold Member
Bethlehem, Pa
Kioti nx6010 loader backhoe
I have a 2010 Ct450 with around 318hours. My unit is hydro. Is it normal if you have the machine throttle up and pull forwards the rpms drop a little tell you get moving and come back up? I haven't taken it out in a little bit can't remember if it always did that. If its not normal what could be wrong? thanks
/ RPMS drop moving forward? #2
Is the brake on? My HST never changes rpms unless I overload it.
/ RPMS drop moving forward? #3
You will notice a RPM drop the higher of a gear you are in. Low range you may not see any RPM drop.:thumbsup:
Thanks guy. I called the dealer find out about installing cab and asked about that to all is good. The price to install the cab not worth it. Im going to sell my machine up grade to something with a cab. thanks
/ RPMS drop moving forward? #5
Yep, if it didn't you aren't putting it under much of a load. A electrically throttled machine will stay constant but a mechanical one will drop a bit. CJ
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
2014 Takeuchi TS50R Compact Wheel Loader Skid Steer (A61572)
2014 Takeuchi...
Caterpillar 416/426/428/436/438B Backhoe Service Manual (A63117)
Caterpillar...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
