SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,646
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I find the optimum will vary per attached implement. You will have to choose a number. 10 degrees past/behind vertical is about right. ... A tinybit more if you can afford the reduced dump angle. ... My Mahindra 7520 is about -5 and is ~ OK -- Id like more and will be increasing it. The Woods loader on the Kubot L3450 is 0/90 and its problematic on many implements. Harder to make a change there though.Alright man I thought I knew what I was doing. Now I'm more confused then ever .
...when the loader arms are lowered to be level with the ground and the curl cylinders are retracted all the way what is the angle that the face of the latch boxes should be at?
